coolant leak? any ideas?
Old Apr 3, 2013 | 03:27 PM
4DGA32's Avatar
Got a coolant leak, any ideas or suggestions where its coming from?
water pump?
It drips only a little, but i gotta replace it asap.
Old Apr 3, 2013 | 05:16 PM
theWalkinator's Avatar
Can't tell from the picture where is the leaking area, if from passenger side behind passenger side wheel, it might be the water pump O-ring, you need either replace the O-rings or replace the entire water pump, it is a common problem on 4th gen Maxima.
Old Apr 3, 2013 | 05:35 PM
maxima2fst4u's Avatar
water pump...mines doing it now seeping out the seep whole mine only leaks sometimes not really worried about at the moment due to swaping in a vq35
Old Apr 3, 2013 | 06:54 PM
4DGA32's Avatar
ohh sorry, i flipped the pic but when i uploaded it, it came like this, oh and i knew it! damn, i just watched videos on how to remove and replace it. thanks for letting me know.
Old Apr 3, 2013 | 06:56 PM
4DGA32's Avatar
i bet mine is leaking through the o rings right? in the back of the water pump?
Old Apr 3, 2013 | 07:49 PM
Yes, there are two O-rings, inner O-ring seals coolant and outer seals oil, see the following picture, if the inner O-ring fails, coolant will leak out through the seeping hole:
Search this forum and youtube, you will find many DIY and videos.
Old Apr 4, 2013 | 10:26 AM
4DGA32's Avatar
Ok so oil wont get in my engine right? Thanks for the heads up!
Old Apr 4, 2013 | 10:55 AM
luke95gxe's Avatar
lol oil is in the engine you mean coolant
Old Apr 4, 2013 | 05:15 PM
4DGA32's Avatar
Hahaha yeah opps just jonzed earlier
Old Apr 4, 2013 | 07:28 PM
Well, you need to drain coolant and oil anyway before you start taking it off, so an oil change at the same time. Mine is leaking at the same spot too so I need to do it in near future.
Old Apr 4, 2013 | 08:33 PM
simmers96's Avatar
It's a fun task. You will probably want to replace the timing chain tensioner while your doing it. Oh big note. Water pump bolt torque in manual is in INCH POUNDS.
You will have to change oil afterwords since coolant will drain out of water pump hole into timing chain cover.
Other note, get an extendable magnet, will help to remove water pump bolts, without droping in timing chain cover.
You don't have to remove motor mount. a swivl is nice.
The link is in 4th gen disscussion, 4th gen how to's.
http://vqpower.com/v3/content/water-pump-replacement
Old Apr 8, 2013 | 09:23 AM
4DGA32's Avatar
Thanks! I will be doing this job in a few months.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
followthadollar
Sep 17, 2015 06:31 PM
Hdnseek
Sep 9, 2015 05:55 AM
