question for GLE owners
i own a 95 gxe.......but i have also seen the GLE's......i dont recall them having the indicator lights......how are u going to install them anyways???? - its a pretty kool idea.......i wonder if its really doable
:o)
Crap!! This reminds me of the hidden "amb" for ambient/outside temperature hidden in the electronic climate control that we can't activate/use! The two things I wish the Max had were outside temperature display and the PRND in the instrument cluster. So are you saying the PRND is actually hidden back there?! Shoot. Nice discovery. If someone could get this to work, I'd be one happy camper.
P.s. But to answer your question as asked, no, the GLEs do not have the PRND in the cluster.
Re: question for GLE owners
Originally posted by slammed95
When I took out the gauge cluster on my 95 to install the indiglos I saw 6 light bulb holes labeled P,R,N,D,2,1 on the back.
I never took my gauge cluster out but definately will if they are "pre-wired".
I was thinking about adding a home-made PRND21 but quickly abandoned that idea.
Originally posted by BluFlame
yeah mine doesnt have it, but i'd love to have it. When i opened console i remember seeing a connector taped up around the shifter base, i wonder if that's the one?
Re: :o)
Re: Re: :o)
Originally posted by mAdD MAX
The Maxima does have a AMB button which tells you outside temperature. I know mine does. It's a '99 GLE.
Originally posted by AznStevie
there were posts about the amb a while ago, wondering how it came out, because 97 up maxs can actually have a amb button put in, but 95-96 are different...if there is a way...that would be so nice.
Re: Re: :o)
Actually the 89-90 Max GXE with the Luxury package had Ambient Temp button, Nissan dropped it for 91 then it appeared again in the 92-94 MAX GXE with the luxury package. Then in 95-98 they dropped it again only to reappear in 99.
Re: Re: Re: question for GLE owners
Yes, the holes hold bulbs because I put in the ones that go behind the gauges. The connection is already their on the circuitboard, and the lights light up according to the selected gear. The only thing needed to complete this project are the six lighbulbs with the orange sockets, and a gauge cluster cover with the gear indicators on it.
Re: Re: Re: Re: Re: question for GLE owners
Maybe the 4th gen I-30's have this feature and we can use the face plate for them.
Yes, the black gauge face plate is the only thing preventing the lights to show. Without the black gauge face plate all you see is the bulb, so we need a face plate that has the letters and numbers on it. They should look the same as where the lights are for o/d off, seatbelt, airbag etc.. Maybe the 4th gen I-30's have this feature and we can use the face plate for them.
Erik
The only thing I can't figure out about this mod is where to get the appropriate gauge cluster face plate. I can't even imagine why the 4th gens have the connnections and bulb holes on circuit board of the gauge cluster if neither any trim maximas nor I-30's have this feature. There has to be a reason for those connections to be there.
Non-U.S. Maximas perhaps?
Under the condition that PRND21 light bulbs are all working, to me there are two things to consider: 1) where to get the face plate with PRND21; 2) is it easy to self-install? I read some post about taking gauge needles out, having problems, etc.
The Cefiro, Australian Maxima and UK/Euro QX all have had the cluster face you need fitted to certain models. As correctly mentioned earlier some 3rd Gens also had the display feature, I gave away a JDM cluster with it fitted just recently.
...I'm currently working on a harness for the needed connections, but need to find a source that knows which gear the car is currently in...
On that switch, many poles are open-circuited, therefore when using those poles an nearly "open-circuit" circuit should be connected in order not to change its original operation.
I don't know where the switch is located, maybe somewhere near the shifter lever?
Seems a lot of work but possible.
it might be best(and easier)to get the complete UK/jdm gage cluster with the face plate and bulbs already in it. before you build it, you need to see what it looks like right? An FSM from australia or nz can help too, i dunno if anybody has it?
Ask RoAdBeast.. see what he has. Either PM or email.
I have an SE and would LOVE this. I mihgt havk open my cluster tuesday to see what I can see
anyone remember NZ MAx he had a max in nz and maybe he could tell us
...and maybe just maybe a face plate off a 92-96 camry or 95-99 avalon could fit our cars cuz it looks very close
It can be done
The pic is from JDM cefiro and it has the gear indicator.
(letme know if the link is broken, BTW pic from megamax)
http://community.webshots.com/user/bluflame88
Re: It can be done
No lights in PRND21, could it just be a place holder, with no function? Can we take our black face plate to a fine milling shop and let them mill the letters. Or let them just mill the center slot, and we print PRND21 on a sheet of transparent (actually I did already, just for fun to look at, the letter is transparent, everywhere else is black to block the light), and stick it on back side of face plate.
Someone found there is no connection to those six bulbs? And haven't found where the PRND21 switch is to connect to bulbs.
Still lots of work but it is very attractive.
98 actually.
My car has the same climate control as the 99 and I have AMB.
war eagle
Originally posted by WaarrEagle
Its actually 98 and up because they got the different auto climate control unit than the 97's. I have a 97 and my temp up/down are circular and on the left and I don't have a place for the buttom to go.
Re: war eagle
Originally posted by aufb1957
I was just trying to get some help with my 97SE and I happened upon the Auburn tag and wanted to say War Eagle to you!
Huh?
...I'm close(hopefully) to getting the gear indicator lights to correspond to the correct gears...I have also tried the black plastic film with white letters, but it was a little too dark.
Mar 12, 2020 12:06 AM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 11, 2015 05:29 PM
