jsutter iacv solution problem
Old Apr 17, 2013 | 05:48 AM
98maxmatt1's Avatar
Hey guys, wondering if anyone has done jshutter iacv solution with the pvc. I did and the block off plate for tb. Sounds like when I start the car,car sucking too much air. Have to hold the gas pedal down for car to start and keep running. As soon as I let go of the gas it stalls out. Prior to this,Had wired up the 5th gen connector for iacv and car after warmed up idled high. Didn't know if anyone could tell me how to fix this. I'm stuck. Also, I can't read dtc's since swap and vafc 1 install. Any comments on that?
Old Apr 17, 2013 | 06:02 AM
Kevlo911's Avatar
Kevlo for President
you have a vacuum leak
Old Apr 17, 2013 | 07:53 AM
98maxmatt1's Avatar
Car started fine b4 I did jsutter adaptor. That's all that changed. Can't b a vacuum leak
Old Apr 17, 2013 | 08:46 AM
CallMeThatOneGuy's Avatar
Then you did it wrong.. The adapter plate works. Check again for vacuum leaks. The adapter plate is going to sound a little louder too I assume. Make sure the lines are held on good and make sure it's sealed around theadapter plate and iacv.
Old Apr 17, 2013 | 09:18 AM
Fakie J Farkerton's Avatar
Vacuum leak.
Old Apr 17, 2013 | 09:50 AM
Amerikaner83's Avatar
Originally Posted by Fakie J Farkerton
Vacuum leak.
Old Apr 17, 2013 | 10:34 AM
98maxmatt1's Avatar
Alright I'll double check again, any clues on the not being able to scan the check engine light since the swap
Old Apr 17, 2013 | 10:55 AM
Does it give error message of not connecting? You probably either blew a fuse related to the OBD port or there's a connector that ain't connected..or a wire or two pinched.
Old Apr 17, 2013 | 12:49 PM
98maxmatt1's Avatar
Yeah, it's giving me that message. I checked all fuses. What connector would prevent me from scanning a code. I tried shaking the wiring harness and trying again. No luck.
matts95max
Apr 23, 2025 10:44 AM
junito1
Sep 23, 2015 12:14 PM
jchronis2552
Sep 21, 2015 05:52 AM
bumpypickle
Sep 20, 2015 08:22 AM
nbstriker10
Sep 4, 2015 04:26 PM
