O2 Sensor!!! Questions?
Old Jan 13, 2002 | 01:46 PM
djleex95's Avatar
Hey guys. I don't know too much stuff about all these sensors, but I had a check engine light come on and found out it was an O2 sensor. Is it bad if I continue driving without replacing it? Does it do more damage to my car if I prolong it?
Old Jan 13, 2002 | 02:23 PM
blakkrob's Avatar
Same here
I have the seem thing happen to me the only thing that'll happen is you'll get terrible gas mileage. But you'll be ok till you can get it replaced. The sensors sends a signal to the injectors to maintain proper ratio. So you're ratio will be screwed and you'll run richer(burn more gas)
Old Jan 13, 2002 | 02:28 PM
djleex95's Avatar
Re: Same here
i use supreme unleaded and do both city/highway and run at a max of 300 miles before next fill-up. is this normal???
Old Jan 13, 2002 | 02:30 PM
jayanth's Avatar
O2 Sensor!!!
I had problems with O2 and KNOCK sensors, the car was running fine.
Old Jan 13, 2002 | 02:33 PM
deezo's Avatar
Its said that your car will use more fuel. I had my rear 02 sensor trip the ECU trouble code so I reset the ECU and it didn't come back. The car is running fine.
Old Jan 13, 2002 | 02:35 PM
Sprint's Avatar
cause your car to run too rich.. i would say go to the dealership and buy another one and replace it yoruself.. its a 10 min job
Old Jan 13, 2002 | 02:36 PM
djleex95's Avatar
yea, the light came on before and then turned off. it just recently turned on again. i just don't feel like spending the $ on getting it fixed right now.
Old Jan 13, 2002 | 02:39 PM
djleex95's Avatar
is it that easy to replace??? estimates told me like $300 to replace.
Old Jan 13, 2002 | 03:17 PM
blakkrob's Avatar
Sensors
Thats probably an estimate to replace all three sensors, it may only be 1 of the 3 though. They are just a lil over $100 bucks each
Old Jan 13, 2002 | 04:15 PM
Pappa Grande's Avatar
Re: Sensors
Humor me.
What kind of gas are you guys running? I was cheating for a while with 87, got the knock sensor and o2 sensor code, reset the ECU, only used 91 plus gas and haven't had the light come back on. Making sure your using the right gas is worth a shot with this common o2 sens. problem...
Old Jan 13, 2002 | 04:26 PM
djleex95's Avatar
Re: Re: Sensors
I always use 91+ and I've had a past of O2 sensors going out on my 95 max. like i said before, i had this light come on once then went out...but came on again and stayed on ever since. i'm doing about 300 max miles before next fill-up. don't know if that's avg or less because of my O2 sensor out. anyway, i hope it won't ruin my car. haha.
Old Jan 13, 2002 | 04:27 PM
Sprint's Avatar
replacing an O2 Sensor is easy... just jack up the passengers side front tire.. then look under the car.. you will see them.. you need a 22" open ended wrench... then follow it up to the engine compartmenet for the electrical connector and then replace
Old Jan 13, 2002 | 04:30 PM
Ants97SE's Avatar
Sprints helpful post of the day!
Old Jan 13, 2002 | 04:35 PM
Re: Re: Re: Sensors
Interesting. I still got 425-450 - highway miles even when my CEL was on for the o2 and knock sensor (pure NJ highway commuting miles)
It won't ruin your care, but your o2 sensor is probably shot...
Old Jan 13, 2002 | 04:48 PM
Sprint's Avatar
visit the 4th Gen Forum more often
Old Jan 13, 2002 | 07:29 PM
ejj's Avatar
ejj
The O2 sensor itself doesn't have the threads for the hole on it does it? If not, is the "housing" with the threads a seperate part that I can order from Nissan (I'm talking about the rear O2 sensor).
Old Jan 13, 2002 | 07:34 PM
Sprint's Avatar
i have never changed the rear.. but the 2 Front ones have threads around them
Old Jan 13, 2002 | 07:36 PM
ejj's Avatar
ejj
Hmm, I'll have to look into it. I just bought a new rear sensor for my 97, and it isn't threaded...
fun...
Old Jan 13, 2002 | 07:40 PM
Eric L.'s Avatar
I just replaced the front bank (LH) O2 sensor on my car this past weekend. Took about one minute to remove the sensor, but about 20 minutes to get those three plastic clips out from the old mounting harness. Mileage is back up again (got 14 MPG before)...CEL is off and hasn't come back.
I would suggest changing the bad O2 sensor ASAP. The mileage difference is significant, and every tank where you get 14MPG instead of 20MPG costs $$$
Old Mar 24, 2003 | 11:29 AM
Str8ridin's Avatar
What about performance? Bad O2 sensors will hurt you gas mileage, but accleration too?
bbsitum
Sep 6, 2019 07:31 PM
220k+ A32
Sep 11, 2015 02:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
