Rear window defroster help.
Old May 3, 2013 | 02:03 AM
Richie110's Avatar
I had my maxima for a year now, and the defroster in the back is one of the worst things I cant seem to fix.. Only like 4 out of the 12 or 13 lines work, idk if is the window or what, what can I replace or I might just need a new window?
Old May 3, 2013 | 03:21 AM
Aflion's Avatar
Never heard of that problem. Maybe try to clean the connector that goes to the window. But the heating elements in the glass may have died.
Posted from Maxima.org App for Android
Old May 3, 2013 | 08:38 AM
DennisMik's Avatar
The lines that make up the defogger are pretty thin and susceptible to being cut or broken. There is a procedure in the fsm on how to find the cuts/breaks.
See page 123 of the EL section:
http://boredmder.com/FSMs/Nissan/Maxima/1997/EL.pdf
Hope this helps.
Old May 3, 2013 | 12:50 PM
Noir's Avatar
Just in case you didn't know, the top few lines that are shaped a little different and connected at odd points are an antennae, not part of the defroster. Not that that fixes your problem, but it is an interesting tidbit I just found out recently..
Old May 4, 2013 | 12:45 AM
Richie110's Avatar
Thanks guys i appreciate it.
Old May 4, 2013 | 01:27 PM
LONDART's Avatar
Once you find the broken lines permatex makes a product to fix it..part # 15067 about $12
Old May 4, 2013 | 02:29 PM
maxfever1987's Avatar
If u have had tints on ur car and removed them to reapply new tints, this is a possibility as to why this can occur
matts95max
Apr 23, 2025 10:44 AM
The Frye
Feb 3, 2019 08:34 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
