Wired harness correctly, new touch screen head unit not working?
Old May 13, 2013 | 04:59 PM
Dondon321's Avatar
I have the bose system, bought a metra harness adapter from best buy for 20 bucks. matched the wires and plugged them in. I only connected the radio to the car to test it, but when I turned on the car, I get nothing.
Old May 13, 2013 | 05:13 PM
cruzmendez08's Avatar
double check to see that the radio is grounded to the car thats what happen to me and after 2 days i notice that the wiring for my 96 was missing the ground wire so i put a separate wire that i screwed on to the body and it turned on
Old May 13, 2013 | 05:48 PM
Dondon321's Avatar
Yeah, the black ground wires are connected. Idk what the problem could be.
Old May 13, 2013 | 06:09 PM
bprice92's Avatar
First thought - radio fuse, blew mine without knowing, very easy to do, check that first. A problem I had when was original harness adapter didn't fully connect, probably not your issue, but verify connector does not move when you tug on it. Hopefully you soldered the wires, I had soldered mine but had to redo due to my HU going off intermittently.
Old May 13, 2013 | 07:09 PM
cjandura's Avatar
The harness ground is not good for the radio ground.just ground the radio to the frame somewhere.
Old May 14, 2013 | 05:34 AM
Dondon321's Avatar
What do you mean ground the radio to the frame
Old May 14, 2013 | 06:27 AM
mrjamaica98mx's Avatar
frame = any metal part of car i guarantee u blew a fuse check under hood and dnt forget bose blue/white wire needs power
Old May 17, 2013 | 12:57 PM
svillegas2253's Avatar
Same happened to me when changing head units. It can be more than just a fuse sometimes, mine kept burning fuses every time I changed it and stereo, clock, and keyless entry alarm wouldn't work. Best thing is chcking all fuse ports (under steering-wheel) and make sure there's no fried wires
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
MikesChevelle
Aug 9, 2015 11:50 AM
MikesChevelle
Aug 6, 2015 11:36 AM
