MAP sensor question
Old Jun 2, 2013 | 07:55 PM
Jbeck's Avatar
MAP sensor question
I pulled the codes from my 96 SE 5sp. I got an evap purge canister code and a manifold absolute pressure sensor code. My car does putt at idle (randomly) and I have degraded performance...hesitation, acceleration seems almost as if I had vtec, the rpms climb slowly and then fast and then cuts out again. Could the MAP sensor code be the culprit? Idle is high as well, 950-1000 rpm and that's as low as it will go even with adjusting.
P.S. I notice the bad performance and misfire when the car has warmed up
Old Jun 2, 2013 | 08:25 PM
maxfever1987's Avatar
Code numbers?
Old Jun 3, 2013 | 12:59 AM
Jbeck's Avatar
Originally Posted by maxfever1987
Code numbers?
I'll report back on this soon, my buddy is the one with the diagnostics tool. Idr the numbers but I'll find them out.
mvm062
Nov 30, 2020 09:00 AM
220k+ A32
Sep 11, 2015 02:18 AM
dcardello
Sep 3, 2015 11:44 PM
sdotcarter
Sep 2, 2015 09:53 PM
