NEW! brake upgrade idea
Old Jan 14, 2002 | 10:59 AM
theblue's Avatar
please respond with how well you think this setup would work and the difficulty / cost or making it happen.
move from brake setup to back.
put 2002 front brakes on the front.
use aftermarket rotors and pads + SS brake lines all around
Old Jan 14, 2002 | 11:01 AM
Jeff92se's Avatar
I'm needing a caw
If the fronts are just bolt on, it should be easy. But putting the fronts on the rears will be pretty difficult/expensive. Expecially if you dink w/ the emergency brake issue. And if the new rears aren't that much weaker than the new fronts, the back end might want to lead the front end around sometimes
Sprint's Avatar
why? its cheaper and better to use phuongs brake upgrade for $540.. its not like its a 300zx or nothing..
did you know that the 2000 Sentra SE has better brakes than the 2000 Maxima SE? bigger rotors... better calipers?
Old Jan 14, 2002 | 11:03 AM
njmaxseltd's Avatar
You can't be serious?
Old Jan 14, 2002 | 11:04 AM
theblue's Avatar
according to DMBmaxima, the 2002 has much improved, larger front brakes than the 2000
Sprint's Avatar
nope.. russ did a comparison.. because he had a 2000 Max SE and then he went to the 2001 Sentra SE.. and he took pics and told us..
Old Jan 14, 2002 | 11:06 AM
Sprint's Avatar
and according to the robot the Z32TT has much more improved, larger front brakes than the 2002 maxima.. and the brake upgrade will be cheaper
Maxboy23
55
May 1, 2025 06:09 PM
toyoking
Sep 16, 2015 07:05 AM
2012Maximus
Sep 10, 2015 12:50 AM
Maxboy23
Sep 9, 2015 10:37 AM
