Axles will not seat in Quaife LSD HELP!!!!
Old Jun 28, 2013 | 07:56 PM
IanC83's Avatar
I had my transmission shop install my quaife a couple weeks back. They would not finish the job because the rear main seal was leaking. I had the car towed back to my friends house and we replace the seal and reinstalled the tranny. The problem I am having now is the axles are not seating all the way into the diff. There is around a half inch gap between and axle and tranny but it will not go in any farther. I thought i might of needed an lsd axle so i order one and that also did not work. The lsd seems to be working. I started the car and put it into gear on the lift and both wheels turn in the same direction. There is also up and down movement in both axles and I feel if any torque is applied it will destroy the diff and axles. I also replaced both output shaft seals and passenger side is leaking like a sive. Anybody had or have a quaife installed or another lsd with this similar problem? I am going to give quaife a call on monday if I can not get this figured out before then.
thanks all
Old Jun 28, 2013 | 08:28 PM
Crusher103's Avatar
Open diff axles are what you need plus a mallet. Put the axle in as far as it will go and tap it with the mallet until it completely seats. If mallet does not work move to a hammer, if that doesnt work move a small 5-10lbs sludge hammer. Dont swing the hammer, tap it. It will go in, axles are difficult to get in and pull off by my nature. Everybody's are, Quaife, VLSD, or open diff, i have experience with all three.
Old Jun 28, 2013 | 08:38 PM
IanC83's Avatar
The hammer/mallet/sledge technique were all tried with no avail. I really don't want to keep tapping or whacking on it and end up damaging the bearing on the diff.
Old Jun 28, 2013 | 10:22 PM
asand1's Avatar
Grease the clip rings to keep them centered.
Old Jun 29, 2013 | 04:32 AM
IanC83's Avatar
Seems to me that that little clip ring would not be the issue. My friend and I both gave it quite a few hard taps with the sledge and it not even move in the slightest. We did cover the splines and opening with gear oil to help it seat better but it is like the axle is hitting a stone wall.
Old Jun 29, 2013 | 11:21 AM
Nealoc187's Avatar
SLOW
is just one axle not going in all the way or are both not going in all the way?
Old Jun 29, 2013 | 12:25 PM
IanC83's Avatar
Both axles are not seating all the way in. Passenger side leaks and has up and down play as well as forward and back movement. Driver side has up and down play and at present moment does not leak.
Old Jun 29, 2013 | 02:18 PM
Nealoc187's Avatar
SLOW
can you get an in-focus pic of both axles at the trans?
Old Jun 29, 2013 | 04:56 PM
IanC83's Avatar
I can do that tomorrow afternoon. I do have one image it's a little out of focus but I can try to upload it and then get some better images tomorrow. Ivan never figure out how to add images into the post.
Old Jun 29, 2013 | 07:11 PM
maxgtr2000's Avatar
KH3 by popular demand
Just make sure you have the right axles. I have ordered axles and they would give the wrong one until I physically took the old axle down there and matched it verses what they had in stock. This would be hard to do if this is the first time you are putting axles in the quaife.
Old Jun 29, 2013 | 07:16 PM
IanC83's Avatar
The LSD is used with about 12000 miles on it. I have tried the LSD axle and my original axles and neither seem to be going in.
Old Jun 30, 2013 | 05:01 AM
IanC83's Avatar
here is the the driver side axle pic with it not seating. this is as far as it will go in.
I am going to head over to the car today and get better photos to post.
Old Jun 30, 2013 | 02:40 PM
Nealoc187's Avatar
SLOW
get some with better light than that, that will help. is that the dust cup on there? if so, it looks like it is basically right up against the seal where it should be, but hard to tell in that light.
Old Jun 30, 2013 | 02:57 PM
IanC83's Avatar
problem has been alleviated. The driver side is good. The passenger sides seal was just pushed in to far. Removed the seal put a new one in half as far and the leaking stopped. Drove the car around but now its skipping a little in second and third gear. I am thinking its spark plugs. It does have 159,000 on it. I have replace them at least once maybe even twice since I bought the car with 55,000 miles.
Old Jul 2, 2013 | 12:26 PM
Max streets's Avatar
Were did u get a quafie from
Old Jul 2, 2013 | 06:08 PM
IanC83's Avatar
I bought it used about a year an half ago and final had the money to get it installed
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
