Fuel filter
Old Aug 2, 2013 | 06:57 PM
granturissimus's Avatar
Fuel filter
We replaced our car's fuel filter, and about 2 weeks after, the engine started shaking when at a red light, as if it's about to stall. It is not constant shaking, but just from time to time, on average every 3 seconds one shake. This happens only at idle when at a red light.
When we pour techron into the gas tank, the shaking almost disappears, gives one shake during the whole red light or so.
Could a faulty new fuel filter be the cause of this?
I got the filter from Auto Zone, and when we took out the old one from our car, the new one was much lighter in weight than the one we took out. Is this a bad sign, or are the new ones supposed to be lighter?
Old Aug 2, 2013 | 07:14 PM
deathwobble's Avatar
Are you sure it was put in the right way? They have a direction of flow. Could be your problem
Old Aug 2, 2013 | 07:53 PM
M in KC's Avatar
the old one will be heavier than the new as there is fuel and contaminants trapped in it.
Old Aug 2, 2013 | 08:50 PM
98maxaholic's Avatar
vaccuum line?
[QUOTE=granturissimus;8832792]We replaced our car's fuel filter, and about 2 weeks after, the engine started shaking when at a red light, as if it's about to stall.
My buddy has a 97 gle and the same exact thing happened to him, after he changed he fuel filter he had rough idle at red lights...if i remember correctly he had knocked a vaccuum line loose or cracked one when reaching into the filter area...
Old Aug 2, 2013 | 08:55 PM
vaccuum line?
"We replaced our car's fuel filter, and about 2 weeks after, the engine started shaking when at a red light, as if it's about to stall"
Old Aug 3, 2013 | 08:42 PM
What is a vacuum line?
Old Aug 3, 2013 | 09:53 PM
DennisMik's Avatar
Old Aug 4, 2013 | 01:35 AM
lol
Old Aug 4, 2013 | 04:24 AM
Max139617's Avatar
It's a hose that you can use to clean up the engine bay with when it gets dirty. Nissan engineers were way ahead of there time.
Old Aug 5, 2013 | 08:26 AM
Phromethius's Avatar
if you checked your latest fix, the Filter, and thats good to go, the next probable cause is a handful of other things. A leak in your vacuum lines or a faulty IACV could cause idle hiccups. Even bad coils can cause what you are describing. Start with what you did last and go from there. Check your work.
Old Aug 5, 2013 | 09:18 AM
bumpypickle's Avatar
If the car wasn't running the that way before you changed it id say it probably isn't the iacv ^ although its worth a check. Id reccomend buying a hastings fuel filter you'll find which exact part number to get if you search through this forum. Also get the hanyes manual. They sell them at autozone for fairly cheap and is a whole lot more useful than these *** holes 2cents
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
Justin Kroll
Oct 1, 2015 07:03 PM
