How would i know if I need new rotors?
Old Jan 15, 2002 | 09:34 PM
baby_boy21
Tomorrow im getting new brake pads in the front and its running me about $90 installed. The reason bieng is im hearing a rubbing or ticking noise, as if the sensor is telling me my brakes are low. I just hope i don't need new rotors cuz i can't afford them right now.
I just hope i don't need new rotors.
Old Jan 15, 2002 | 09:40 PM
95emeraldgxe's Avatar
you can tell that u need new ones if the surface isnt smoothe
Old Jan 15, 2002 | 09:47 PM
finny's Avatar
wow 90 bucks for front brakes. i put brakes on a few dif cars and the max was the easiest. like 25 bucks for lifetime pads and took me like a half hour to do em. buy a service manual and do it yourself and save some money, its worth it
Old Jan 15, 2002 | 09:50 PM
baby_boy21
What do you mean if the surface isn't smooth? Just trying to really know what i am looking for
Old Jan 15, 2002 | 09:52 PM
BillN
When applying your brakes...you may feel a surge like sensation. almost like your pumping your brakes. this is how i knoew it was time for new rotors.
Old Jan 16, 2002 | 05:23 AM
marcel's Avatar
Can't the roters be resurfaced at least once?
Old Jan 16, 2002 | 06:48 AM
njmaxseltd's Avatar
Yes they can be resurfaced a few times depending on the thickness of them. There is a minimum spec for the rotors. You can resurface them until you get to thin. If somebody on here has a factory service manual, please post the min. measurements of the front and rear rotors.
Old Jan 16, 2002 | 08:51 AM
baby_boy21
Just got back from the shop and found out im gonna have to spend about $550 for new rotors and brake pads all around. I can't believe this.
The sad part is i won't have the money for about another 2 weeks
What is this world coming too?
Old Jan 16, 2002 | 08:57 AM
njmaxseltd's Avatar
Just got back from the shop and found out im gonna have to spend about $550 for new rotors and brake pads all around.:
For $540 you can put high performance drilled rotors and Metal Axis pads with new SS Brake lines and Motul brake fluid. Get the kit from www.eatricezone.com
Save you 10 bucks and you wind up with much better brakes.
Old Jan 16, 2002 | 09:14 AM
baby_boy21
Thanks alot, im gonna look into that. Does anyone else know of any better brake kits for the same price?
Old Jan 16, 2002 | 09:29 AM
Just run your fingers along the rotors....and if they feel kinda uneven.....you should consider resurfacing
Old Jan 16, 2002 | 09:39 AM
JAIMECBR900's Avatar
Folks....don't make this any more difficult than it needs to be. If the young man doesn't have the money to get the brakes done, then his best option is to do it himself. The front brake pads are very easily changed, and while doing it he can just pull the rotors off and take them to the local shop to have them turned. They may charge like $10-20 a piece to do it and he comes back and puts them on. Lifetime pads from auto parts are usually about $25 and the whole job can be done without much effort for around $75 at most. The brake shop is going to try and make their money by telling him his rotors suck, his calipers suck, and his brake pads suck, that's their job to make money. Unless he has serious brake problems, i.e. bad calipers or completely shot rotors, this is not a real big project. A floor jack, towers, and an hour or two and the job is done and better yet probably better than if you pay someone to do it. If your in GA, let me know and you can come over to the house and I'll help ya. Good luck.
Old Jan 16, 2002 | 09:46 AM
NISMO808's Avatar
What are lifetime pads? Is that a specific brand?
Old Jan 16, 2002 | 09:55 AM
Not a specific brand, just call your local auto parts store and get a price for pads for the the car. If they are offered, they will ask you if you want cheapo pads for like $10 or the lifetime ones for $25. I had good experience from an auto parts store called AutoZone here in GA. I bought lifetime pads for another car I had. I have not paid for a set of pads for that car since 1999. I just take them the pads in the box, the worn out ones, and they go to the shelf and hand me a new set and I go home and put on the new ones. Not a penny charged. That sometimes is rare because most "lifetime" warranties have a lot of fine print B.S. so beware.
Old Jan 16, 2002 | 10:25 AM
NISMO808's Avatar
thanks for the 411
Old Jan 16, 2002 | 10:28 AM
thanks for the 411
not a prob...
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
