Pleeasse HELP! New battery/alternator. Car DIED.
Old Sep 6, 2013 | 06:49 PM
Middleqy's Avatar
About 2-3 weeks ago I replace my exhaust, everything from the cat back, BRAND NEW. Previous to that the alternator was changed, a month or 2 before that the battery was replaced. Just recently the lights in my car started going haywire. Air bag, brake and battery. The brake light had been an off and on thing for about 4 days. The battery light came on yesterday. The car died on me tonight, JUST as I pulled up to my house.
Can some PLEASE tell me if there is any explanation or correlation. I've replaced so much on this car, I just can't take it!!
Old Sep 6, 2013 | 06:53 PM
Alternator is faulty most likely.
Old Sep 6, 2013 | 07:16 PM
D I R T Y I 3 0's Avatar
Check your alternator harness, you might have messed up the pins. If the alternator checks out, I bet it's the harness - that's what happened to me
Old Sep 6, 2013 | 07:51 PM
Trini Boom's Avatar
Where did you get the alternator from?
Old Sep 6, 2013 | 07:52 PM
Middleqy's Avatar
Oh my god. You gotta be kidding me. The guy at advanced auto parts said if they used the welder to remove the exhaust that could have done damage.
Old Sep 6, 2013 | 08:54 PM
Max139617's Avatar
lol your first mistake was asking the guy at Advanced Auto to diagnose the problem.
Old Sep 6, 2013 | 08:56 PM
This.
Bring it in and have em test it.
Old Sep 6, 2013 | 09:10 PM
Middleqy's Avatar
I was scared the car was going to die and that was the closest place
Old Sep 7, 2013 | 01:32 AM
Climaxx's Avatar
1: WHY would someone use a WELDER to REMOVE the exhaust?
2: what does removing the exhaust have to do with the alternator not working? Lol
Old Sep 7, 2013 | 05:49 AM
Middleqy's Avatar
This.
Into where?
Old Sep 7, 2013 | 05:53 AM
Middleqy's Avatar
I have no clue. I'm just totally frustrated with this car. The guy said the welder could have blown a fuse and the ground cables could be messed up. (Something to that effect) Though I'm not quite sure it's the alternator yet
Old Sep 7, 2013 | 05:55 AM
Middleqy's Avatar
I'm not sure if its the alternator completely. I doubt a car can run two days on just battery, even though the light was on. I really don't know where to go from here. I'm at wits end with this car
Old Sep 7, 2013 | 06:04 AM
Middleqy's Avatar
I hope that's the case! Now I have to figure out how to get the car up the street to the shop. I KNOW it won't start.
Old Sep 7, 2013 | 06:06 AM
Middleqy's Avatar
A car parts place. I wouldn't call it a junk yard but similar too. It's smaller and they check the parts before reselling.
Old Sep 7, 2013 | 06:15 AM
D.Stillwell's Avatar
If the car starts, it's not the starter.
If your battery is new as of a few weeks, that should be fine too. You can check the battery voltage with a multimeter.
Your exhaust has nothing to do with it, unless somehow the person installing it was an insane moron.
And finally, check your alternator. Take it to Advanced or whatever the closest place is that can do it, and have them bench test your alternator. Chances are, you will discover your problem right then.
But if not, then more info is gonna be needed after this. You should get yourself a jump from a friend, and if it's the alternator the car should start. Then you can drive to the auto store, have them test your alternator, and get yourself a battery charging station so you can start the car until you fix the alternator. I would never use anything but a brand new alternator for the replacement and make sure you get professional installation if you're at all unsure about doing the job.
Old Sep 7, 2013 | 06:19 AM
njmaxseltd's Avatar
1) Nobody uses a welder (electric) to remove an exhaust system, they might use a torch (gas).
2) The person who told you this is an idiot.
3) Check all connections first, both at the alty and at the battery. Take the positive cable connection completely apart. There's one or two additional wires that tie into the terminal. Make sure all are clean and secure.
Old Sep 7, 2013 | 07:26 AM
gatsugansu's Avatar
Similar thing happened to me while back, turned out to be a bad negative terminal cable from battery to the chassis. check negative cable, give it a tug.
Old Sep 7, 2013 | 07:43 AM
Middleqy's Avatar
Ill have to try that, I know the battery was tested and it turned out to be fine. This was Thursday and I believe the alt was still running, even with the battery light on. Other it would have died way before I finished the nights errands. Being that the car didn't die until last night, this is why I don't want to put all my chips on the alt. ( being that one just died on me and it was classic case of a bad alt. didn't even last 2hrs)
Old Sep 7, 2013 | 07:47 AM
Middleqy's Avatar
Your absolutely right. I'm only 22 and this is my first car. I'm learning as I go. Now I was told something about ground cable or cables in general. Hopefully this is the issue and not the alt.
Now do I need mechanic to do this? Or this something I can do myself?
Old Sep 8, 2013 | 05:12 AM
Middleqy's Avatar
I had a friends come and jump me long enough to drive it up the street to the mechanic. He said he'll call me sometime this morning with an answer. Hopefully it's just that.
Old Sep 8, 2013 | 05:53 AM
jholley's Avatar
If it only starts with a jump then your battery is drained. Your either have a faulty alternator or it wasn't properly installed.
If you cannot search to learn how to check the alternator connections nor the battery GND cable then just go to a mechanic.
Old Sep 8, 2013 | 04:06 PM
Middleqy's Avatar
That's why I took it straight to the shop, I didn't trust myself to look at the right thing. I highly doubt it's the alternator, only because of the person who installed it. He was one of those friend of the family/under the table guys and I didn't really trust him 100%. His car logic never made complete sense and he always gave me a hassle. Hopefully my mechanic calls me says it was improperly installed and not damaged. Ground cable issues would be even better. Now I recently had a head light go out but it didn't blow. Replaced it and the new one took a couple of minutes/tries to come on. Is that a sign of ground cable issues?
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
