Video of my car running badly. Need help diagnosing plz..
Old Sep 14, 2013 | 07:26 AM
TSoprano's Avatar
Here is a video of my car running badly. I placed my phone on my dash holder and was trying to go up a small hill with the car. The shaking and shuddering is from it cutting out. I think it might be the maf going bad but it's not throwing a code for it.. Any help in diagnosing it would help alot. I gotta get it fixed today or asap!! Thanks
It's throwing codes for
P1447 Evap control system purge flow monitoring
P0142 Heated O2 sensor bank1 sensor 2
Old Sep 14, 2013 | 10:11 AM
TSoprano's Avatar
Fixed! It was the MAF..
Old Sep 15, 2013 | 12:19 PM
maxi1998's Avatar
My 1996 Maxima jerking, very rough ride, no power
How did you fix it please or did you replace something? My maxi has the same problem. Its jerking so bad that it broke one of the exhaust pipes.
Old Sep 15, 2013 | 12:29 PM
bprice92's Avatar
He replaced the MAF (Mass Air Flow) Sensor as seen below:
It's under the hood, driver side.
Do a search and you'll find countless threads.
Old Sep 15, 2013 | 06:35 PM
TSoprano's Avatar
Your local junkyard should have a used maf for around $40 - $60..
Make sure you reset your ecu after you install it..
After I installed my new (junkyard) maf I forgot to reset my check engine light (ecu reset), I took it for a test drive and acceleration and throttle response were much better. But it did start to shake and shutter once during my test drive. I got it home and reset the ecu and it's been running fine ever since..
RESETTING THE CHECK ENGINE LIGHT
http://vbxmaxima.8m.com/ecu.html
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
