New springs popping
Old Sep 17, 2013 | 11:12 PM
Spencer5556's Avatar
New springs popping
Today, I installed new springs and struts. Afterwards I was left with popping. Here is a video of what is going on. Please help!
It on both sides
H techs
Gr 2's
Old Sep 17, 2013 | 11:13 PM
It on both sides
H techs
Gr 2's
Here is the video
Old Sep 18, 2013 | 12:52 AM
Fakie J Farkerton's Avatar
I say bad upper strut mounts.
Old Sep 18, 2013 | 05:11 AM
njmaxseltd's Avatar
The mount has nothing to do with that.
Did you clock the upper spring perch correctly? The word OUT stamped on the top needs to face outwards, and be in line with the struts lower mounting flange.
Did you replace the bearing? Did you put the bearing in upside down? (Seen that b4)
Make sure the upper spring perch is clocked correctly and replace the strut bearing.
Old Sep 18, 2013 | 07:46 AM
I think it might be that I didnt clock it correctly. I just made sure the spring fit in the right spot and thats about it. The piece that says "out, came seperate from the rubber, so i just made sure the spring was in there right and didnt worry about the pice that goes above the top spring mount rubber. Ill take it all apart and do it again tonight.
Thanks!
Old Sep 18, 2013 | 08:21 AM
Where does the threaded spoke with yellow paint go? I assumed it was the front
Old Sep 18, 2013 | 11:25 AM
njmaxseltd's Avatar
Your talking about the 3 studs on the mount? They will only mount to the car one way.
The upper perch is the top piece that the rubber seat and spring sit on. The bearing sits on top of that and allows the spring and strut assembly to rotate on the strut mount.
Old Sep 18, 2013 | 11:44 AM
I have the spring seated in the rubber correctly, but the perch is in the wrong spot for sure.
It is rotated wrong
Would you say that's prolly my issue?
Old Sep 18, 2013 | 12:27 PM
DjHackStyle's Avatar
Yea the top hat or upper spring perch is facing the wrong direction see djfrestyl thread on suspension in the 5th gen section
http://forums.maxima.org/5th-generat...on-thread.html
Old Sep 18, 2013 | 12:57 PM
What part lol? So many pages
Old Sep 18, 2013 | 03:19 PM
Working on it now
Old Sep 18, 2013 | 03:22 PM
njmaxseltd's Avatar
Post pictures if you have any questions.
Old Sep 18, 2013 | 05:46 PM
Turns out the cap was in the wrong spot, same with baring
Old Sep 18, 2013 | 09:04 PM
asand1's Avatar
You get it fixed? It is pretty obvious from the video that the bearing/mount assembly was binding and not turning smoothly.
Mahmuth
Aug 16, 2024 08:23 PM
D Mason
Jun 21, 2016 04:43 AM
Unclejunebug
Apr 2, 2016 05:42 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
