cali spec and 00vi swap
So I have started contemplating the 00vi swap on my car. I read doing it with all 5th gen parts is the best way to go especially if you are going to tune it with a piggyback. Anyone out there running an 00vi in cali have problems with CEL's and/or not passing smog in california? I tried searching this but the 00vi topic on here just throws out soooooo much info that it is hard to pick through!!!
As far as smog, youre going to need a tune so you wont be running so rich. Youll need a piggyback (ill be using a VAFC2) and either a wideband o2 if you plan on street tuning or access to a dyno shop. Once its tuned proper i believe itll be giving about the same amount of smog as your car gives off currently.
Alternativly if you go the 4th gen LIM and fuel rail route you probably wouldnt need a tune, but it most certainly would be beneficial.
Sounds like were doing the opposite. I'm currently doing a 01 de-k swap into my 99... I'm in FL so not really worried about the emissions stuff I'm trying to eliminate all the cali sensors and stuff. GL with all the emissions goodness lol. Possibly you could find a shady shop to just write you off as pass?
If all the parts come from Cali cars, you don't delete anything like egr and it's tuned right, you shouldn't have any issues. Our emissions testing here in Texas is nowhere near as jacked as they are out there but I've seen the results from a couple of 00vi swap maxis here and the results show little difference in emissions. Hell, my stock 95 with over 224k still has lower emissions than a lot of the newer cars. It's all about keeping it tuned and maintained.
From what ive read however, swapping an 00vi and not tuning results in mediocre gains.
Guess ill have to tune the car, or find another cali spec lower manifold and take it to the machine shop and make new holes and threads...
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
