cam and crank position censor problems starting
my 97 wont crank, crank and cam pos censor said failed. replaced both and still wont start. it started up for about 2 seconds and died like it was out of gas then hit a lick 2xs but acted like it was out of gas. its gettin fire to injectors but no fire to the spark plugs. its gettin gas from fuel filter to motor, any suggestions b4 i spend more money, thank you, im a newbie here
did u replace both crank sensors? one next to the oil filter and one on the flywheel. Use oem sensors and use oem sensor for cam position sensor as well. Those sensors rarely ever fail but if u got a code but if u got a code for them I guess there broke.
no ive only replaced the crank censor on the flywheel, not the one near the oil filter, think that may b the problem is the other crank censor? the computer also called for knock censor but i wouldn think that would have any affect on it not starting.
i heard the starter sends signals to the computer and while cranking the starter wire starts to smoke, could a burnt or bad connection to starter possibly have an affect on the computer not letting it get fire
Yes. I once bought a crank position sensor for my car from auto zone which was aftermarket my car started to misfire at idle. Bought a aftermarket mass air flow sensor my car started to run lean and got a code and the mass air flow sensor was from Bosch as well.
Does the car crank on the first try yes or no. If it doesn't it could be a bad ignition switch if it does crank then it could be something to do with your idle adjustment. What does your car idle at when it is all warm and ready to go.
im not a 100% on "crank" and "turn". basically, when i first turn the key it tries to start and makes the noise but takes a few secs to start or doesnt. When warm it idles at 600-700. i'll make a sound recording with my phone tom.
When you record the video, record the rpm idle gauge from inside the car so I can see where the idle sits. Also record the idle air control valve from under the hood and record the black screw that's on the idle air control valve so I can see where it is at.
Cam and crank position censor problems starting
Well I've replaced both crank sensors and the cam sensor and still won't crank, idk what else to do, any ideas out there? I've checked all the fuses and and relays, it's not gettin fire to spark plug. It tried to start once for like 2 secs but went dead like out of gas, but it's gettin fire to injectors and gas from filter to motor?
Post video that we can hear, inside and outisde the car. That's the quickest way for a lot of us to tell what kind of problem you don't have.
Did you test your sensors? Sometimes an old one still works, and a new one doesn't. You have to test them or swap them with one that you *know* works. The service manual tells you how to test each sensor.
im just gonna take it to a mechanic and let him fix it. i cant afford all this trial and error on all this electronic stuff. when i get it fixed ill repost what was wrong and how he fixed it, ty for the help, was told that both sensors dont just go out at same time that it must b somethin else causing it, so.....
kjlouis
Nov 24, 2018 06:09 AM
conansriver
Sep 3, 2015 06:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
