Alarm chirp issues
Old Nov 14, 2013 | 11:35 AM
Nissanlover365's Avatar
Alarm chirp issues
Alright guys, not sure if this has been covered yet but I have a question. When I hit the lock on my key fob my lights flash and doors lock but no chirp. Ive tried holding down the lock and unlock until it chirps and no luck..& when I press the horn it sounds like the horn is on its last leg. Not sure if that has anything to do with it. Any takers?
Old Nov 14, 2013 | 11:48 AM
njmaxseltd's Avatar
Factory alarm doesn't chirp.
If your horn sounds like crap, clean the connections or replace it.
Old Nov 14, 2013 | 12:05 PM
Thanks!
Old Nov 14, 2013 | 12:13 PM
Not sure if I should create another thread but im having another issue..it seems when my maxima warms up I get this scraping sound from sounds like a pulley or something..like a chatter.
Old Nov 14, 2013 | 12:43 PM
DennisMik's Avatar
I think another thread with an appropriate tile would be better.
As far as the noise goes, what you said it pretty vague. Try to find an approximate location.
Power steering pumps can make noises, make sure the reservoir in full (uses Dexron ATF oil). It could be a belt noise, especially if the crankshaft pulley is coming apart.
Old Nov 14, 2013 | 02:09 PM
Nissanserguy's Avatar
could even be the starter motor gear giving out. I had same kind of issue cause the gear on the starter would stay out after the motor started
Mar 12, 2020 12:06 AM
conansriver
Nov 18, 2015 02:46 PM
wingnut2006
Sep 19, 2015 06:13 AM
BrandonCause
Sep 14, 2015 10:41 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
