too much oil.
Old Nov 19, 2013 | 04:51 PM
bumpypickle's Avatar
too much oil.
So i changed my oil recently and afterwards I noticed I developed an oil leak. I tightened down the drain plug and oil filter but realized that I probably put too much oil in. My question is since I put too much in will it ruin my gasket or drain pan or anything like that? Will it stop leaking when there's enough oil in? Do I have a permanent leak now? Any help is appreciated thanks.
Old Nov 19, 2013 | 05:40 PM
CALIMAX06's Avatar
How much more oil did you put? An extra quart isn't going to do any damage. If your car was leaking from the plug it's probably because you didn't put it on tight enough, not because you put in too much oil. So retightening it should fix it. And if you want to get rid of the extra oil just drain some of it out.
Old Nov 19, 2013 | 05:52 PM
I'd be worried about seals if there's too much oil. Why don't you just check the dipstick? It's there for a reason.
Old Nov 19, 2013 | 05:55 PM
LTXMitch's Avatar
Too much oil wouldn't cause a leak. Not tightening enough Or cross threading the bolt will cause it to leak. I remember I was (and still) am getting a funky sound from the timing chain side of the engine and kept putting in oil because I thought it was low. On the next oil change I emptied out 6 1/2 quarts. The leak is something else probably just your drain plug.
Old Nov 19, 2013 | 06:03 PM
The leak is coming from a random oil pan bolt -_- it is small and I did check the dipstick and its at the full almost a little past but not. I've already lost quite a bit of oil I'm sure but not a lot. If my oil continues to leak is there a sensor that will pop up telling me my oil is too low?
Old Nov 20, 2013 | 05:50 PM
chrome91's Avatar
overfilling the oil enough WILL cause seals to leak and foaming in the crankcase. anything above a smidge above the full mark is too much
how overfull is it exactly? like 3-4mm above the full line isnt gonna cause a leak, anything more than about a quarter liter is bad news. you cant rely on sensors to tell you when your oil is low, you need to get the leak fixed or until then check the oil level daily via the dipstick. oil lights come on when theres not even half a liter of oil left in the system
Old Nov 20, 2013 | 06:43 PM
max ride 41's Avatar
i believe our cars take 4 and a half quarts, drain some if its past the full mark. check when cold on a level surface.
Old Nov 20, 2013 | 09:20 PM
gruesome's Avatar
I accidentally put in too much, blew the precat into my flex pipe causing it to clog on the highway. Hasn't leaked since.
Old Nov 23, 2013 | 04:28 AM
Trini Boom's Avatar
Not sure why some members are saying too much oil will not cause any damage. You had better get that extra oil out of there ASAP if you don't want to be dealing with a RMS replacement because it will be ugly on the pockets..
Old Nov 24, 2013 | 02:47 AM
Climaxx's Avatar
I've never had any issues dumping 5 quarts in.
Old Nov 24, 2013 | 04:42 AM
vqmaxman's Avatar
adding 5qts is 1cm or 2cm above the mark line.
Old Nov 26, 2013 | 09:17 PM
Trini Boom's Avatar
This is true and I have done it myself. When you take it to a shop, its not guaranteed that all of the oil will be drained. Had a shop overfill the engine because they didn't drain out all of old oil and that was the very last time I had someone do my oil changes. It was so overfilled, that I emptied 2 quarts for it to come back to normal and somehow the car drove 500 miles without smoking.
Old Nov 26, 2013 | 09:49 PM
FallenOne's Avatar
I have a nice one for ya, friend of mine went to get his car detailed and his oil changed and a place around me. He always puts Royal Purple Synthetic in his Mazdaspeed 6. He left with the car feeling slugish and odd. Gets home and checks the dipstick.
They forgot to drain the oil. So lets do some math.
6 Quarts + 6 Quarts = blown seals.
Old Nov 29, 2013 | 05:02 PM
I didnt forget to drop my oil I just put in 4 quarts and eyeballed the rest and now I have a leak. Cant be the oil or oil filter because I used the same brand my last oil change and nothing happened.
Old Nov 29, 2013 | 07:03 PM
chrome91's Avatar
if the leak started right after you changed the oil, its too coincidental to not be the oil filter or drain plug leaking. take a look at both
if the old oil filter seal sticks on and you put a new filter on, a double seal will leak oil. usually the oil will **** out in that case but could be what happened to you
Old Nov 29, 2013 | 09:32 PM
Climaxx's Avatar
Wow that's crazy. I do my oil changes with the engine at normal op temp(180ish). Yeah the oil is hot af, but it all comes out, and quick too lol
Old Nov 30, 2013 | 01:44 AM
jfactor's Avatar
4 - 1/2 quarts? Can you say overfill? 4 - 1/4 with filter change on my 95.
Old Nov 30, 2013 | 08:45 AM
Yes I put in 4 but eyeballed the 1/4. Either way im just hoping I dobt have a permanent leak
user 11122324
42
Jul 18, 2022 03:35 PM
spencerwh1
Jun 30, 2016 05:44 AM
foodmanry
Sep 24, 2015 12:02 PM
f.matejaiii
Sep 21, 2015 12:09 PM
ag90fox
Sep 9, 2015 12:22 PM
