High Idle At Cold Start
Old Nov 28, 2013 | 01:20 AM
marxmax4's Avatar
Hey org.
This could be a really easy solution, or a real pain in the ***.
When I cold start in the morning I idle 1500 to 2000.
When it's warmed up, it goes down to a normal idle around 700-900.
It's not a big deal to me and doesn't effect my driving, but it's annoying because it's not normal.
Any ideas or solutions?
Old Nov 28, 2013 | 02:30 AM
TurboA32's Avatar
Check vac lines for connections or breaks
Old Nov 28, 2013 | 02:51 AM
4th gen maxi's Avatar
Its suppose to!
The ecu also enriches until the coolant temp reaches a certain temp.
Old Nov 28, 2013 | 04:52 AM
IceBerg's Avatar
It's normal
Old Nov 28, 2013 | 06:01 AM
njmaxseltd's Avatar
Normal
Old Nov 28, 2013 | 06:54 AM
asand1's Avatar
Yup normal.
Old Nov 28, 2013 | 07:02 AM
njmaxseltd's Avatar
You can bring it down slightly by adjusting the fast idle linkage. It's located under and to the left on the throttle body. Follow the plunger and linkage, you'll see the adjustment screw. You can back it down to around 1500 when you start cold.
Old Nov 28, 2013 | 07:46 AM
IceBerg's Avatar
Leave it as it is anyone else can tell you once you mess with idle it can be a pita to correct
Old Nov 28, 2013 | 10:17 AM
marxmax4's Avatar
Thanks yall! I appreciate the quick responses. Thing is when I first got the car 2 years ago it never did this... But then again, I had a CEL before that I fixed (EGR clogged, MAF was dirty). But if it's normal I wont mess with it.
Old Nov 28, 2013 | 11:29 AM
TurboA32's Avatar
2k rpm on cold start is not normal
Old Nov 29, 2013 | 09:35 PM
Climaxx's Avatar
You guys have some high *** cold start idle! Lol. Mine has never gone more than 1500 rpm
Old Nov 29, 2013 | 09:41 PM
deathwobble's Avatar
Mine is 1k maybe 1300 rpm. 2K rpm is pretty high
Old Nov 29, 2013 | 09:51 PM
chrome91's Avatar
most Mazdas especially older ones cold idle at 2 grand
Maximas i dont think 2 grand is normal, as said check vac lines etc. should be more around the 1500 range
Old Nov 30, 2013 | 01:35 AM
jfactor's Avatar
What do you mean 'not normal'? In cold weather mine starts at around 1500 and goes down to 600-700 when it gets warmed up. My 94 Isuzu Pup and 99 Monte Carlo behaved similarly in cold weather, as does my sisters 01 Neon and my mothers 00 Sentra. I have fairly long list if you need more.
Old Nov 30, 2013 | 01:23 PM
chrome91's Avatar
anything over 2000rpm is kinda bad, right when you start it up in the cold some parts of the engine arent fully lubricated and going over 2 grand can run them dry and can cause issues in the long run
Old Nov 30, 2013 | 06:35 PM
Trini Boom's Avatar
Must agree here. I have two 4th gens in NY and in the teens, both of my 4th gens do not cross 1500RPM at cold start. 2K is definitely a problem and should not be idling at 900 at warm. You should be at 650RPM +/- 50RPM according to FSM.
lowpost99
Oct 26, 2025 06:53 PM
Maxima.KsA
May 15, 2020 04:14 PM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
Justin Kroll
Sep 2, 2015 11:06 AM
