ugh... more problems with the max, Now misfiring when cold
Dec 5, 2013 | 10:57 AM
Honestly the first 5 something years with this car was good, now the last 2 years I been having nothing but problems. I think she is just getting tired. I've had mostly rust and front end issues throughout its life, now its just more front end, (like everything in the front end, legit) and ovb the transmission input shaft bearing, but now the gas strap.
Now my rad is leaking, now this misfire, and I think I have another exhaust leak. I've probably spent close to $1000 dollars on self repairs on this car this year ALONE... I'm getting tired of it. Sure it has 240k something miles on it, but why all of this sudden? 5 years was all minor things now its something new every time. Really kinda shocked to be honest.
Makes no sense and these are my latest codes.
p0306 cly 6 misfire
same 1105 manifold absolute pressure/bar switch solenoid circuit. I could never figure out cause the voltage tested out fine.
heres a new one I never seen...
p0174 Bank 2 system too lean? (faulty o2 sensors perhaps?)
p0154 oxygen circuit no activity detected (bank 2 sensor 1)
Dec 5, 2013 | 01:01 PM
Replace B2S1 O2 sensor.
Dec 5, 2013 | 06:01 PM
B2S1?
Where would that even be? lol
Dec 5, 2013 | 08:10 PM
If you have a minor exhaust leak, don't replace the pipe. Go to home despot out Lowes . For $12 or so, you can get half a gallon of furnace cement. Wear gloves, it's harsh on bare skin. Scoop up a blob of it top cover the hole. Let it sit for a hour, then drive until car is warm, it'll be quieter too.
Dec 5, 2013 | 08:13 PM
b2s1 is only if youre cali. it will be located right behind the radiator
Dec 6, 2013 | 11:27 AM
Quote: b2s1 is only if youre cali. it will be located right behind the radiator
Not in cali. Infact. I forget if my car is fed or cali spec. I will check.
Quote: If you have a minor exhaust leak, don't replace the pipe. Go to home despot out Lowes . For $12 or so, you can get half a gallon of furnace cement. Wear gloves, it's harsh on bare skin. Scoop up a blob of it top cover the hole. Let it sit for a hour, then drive until car is warm, it'll be quieter too.
i'll keep that in mind thanks!
Dec 6, 2013 | 12:47 PM
Replace all the 02 sensors if you can afford it. Whens the last time you did spark plugs etc.
Dec 6, 2013 | 08:01 PM
Quote: Replace all the 02 sensors if you can afford it. Whens the last time you did spark plugs etc.
gave the car a full bottom to top tune up(besides flushing all fluids) this past summer. Fuel filter.. the works. Just an oil change too.
Dec 10, 2013 | 07:04 AM
Don't rule out a bad spark plug. Inspect. I had 1 NGK copper go out on me after just 3,000 miles.
Made the car run like poopy.
Dec 14, 2013 | 08:32 AM
I'll give you the same advice I gave Crusher.
Kill it with fire.
Dec 15, 2013 | 06:31 PM
Put a timing light on your 6 cylinders just too see how each is performing!!!!!
