Starting issues
Old Dec 6, 2013 | 09:27 AM
Jbeck's Avatar
Starting issues
I have had a starting problem for almost a month.
I will sum up the symptoms.
- have to hold key in start position for a minute+ to get the car to start cranking
-once car STARTS cranking it fires right up
-replaced ignition switch
- replaced starter solenoid
- replaced battery wiring
- cleaned up connections from solenoid to starter
- tried starting ign switch with a screwdriver (didn't work)
-if I jump ignition wire to power wire on starter solenoid the car will crank but i still need somebody to turn the keyto start position to actually start the car. (Wont start by just jumping solenoid alone)
-new battery
-new alternator
I don't know where to go from here
P.S. yes I have another thread about this but it got kind of messy. I wanted a fresh thread that clearly states what i have tried or not tried.
Old Dec 6, 2013 | 09:42 AM
theWalkinator's Avatar
1. Switch anti-thief relay with windshield wiper relay
2. Jump inhibitor relay pin 4&7
3. Is your car auto trans? If auto, shift between park and neutral few times.
4. Check inhibitor switch.
Old Dec 6, 2013 | 01:36 PM
Jbeck's Avatar
Haha funny story, I've been avoiding the relays because I lost the cover for them that says which relays are which. But I have a manual transmission.
Old Dec 6, 2013 | 01:54 PM
DennisMik's Avatar
With a manual trans, remove the inhibitor relay and replace it with a jumper in pins 3 and 5. Pin numbers are molded into the socket. Inhibitor relay - stand in front of the car and look at the relay box. The inhibitor relay is in the row closest to the battery, the middle one.
There is a switch on the clutch pedal that, if bad, will prevent the interlock relay from energizing. You could unplug the wire from this switch and put a jumper in the wire harness connector as a test.
Old Dec 6, 2013 | 02:01 PM
DennisMik's Avatar
Don't jump pins 4 & 7 (auto trans). Jump 6 & 7, this lets the ignition switch supply power instead of the cruise control switch.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
