99 Max low beams inop
Old Dec 15, 2013 | 09:17 AM
BabyFaceFinster's Avatar
I am trying to assist my GF and her son from long distance. The low beams are out and I want them to check the fuse. Where is the fuse box on a 99 Max and is it covered with a chart? Thanks all
Old Dec 15, 2013 | 09:58 AM
deathwobble's Avatar
Stupid question. But are you sure the low beams arnt just burned out? I believe the bulbs have two filaments for high and low beams
Old Dec 15, 2013 | 10:38 AM
njmaxseltd's Avatar
Yes, don't rule out the obvious, check the bulbs first.
Old Dec 15, 2013 | 12:18 PM
DennisMik's Avatar
The car uses 2 fuses for the headlights. They are located under the hood between the battery and the fender. The cover is labeled H/LAMP RH and H/LAMP LH.
But as the labels imply, one fuse is for the right headlamp and the other is for the left headlamp. That means that a fuse powers both the high beam and low beam.
And that would mean that you have 2 blown fuses and no high beams as well as low beams.
Check the bulbs, check the fuses.
You wouldn't live in Canada by chance? Sounds like a bad DRL module.
Old Dec 15, 2013 | 06:10 PM
CMax03's Avatar
Check your connector for power with a VOM....It's possible that your light switch/stalk assy is defective.......
DJLAX152
May 4, 2021 11:46 AM
AaronL
Nov 15, 2020 11:52 AM
Maxima.KsA
May 15, 2020 04:14 PM
Excalibur23
Oct 13, 2015 04:33 PM
meccanj98
Sep 16, 2015 06:06 PM
