transmission cooler line replacement q's
so, i'm replacing the smaller of the 2 lines on the right. just wanted to know how much do i add after i replace the line assuming thats tranny fluid coming from it. i know i check the level when it's hot and in park.
you lose so little when you remove the line that it most likely wont even affect the level in the trans that much
if you want to check it, vehicle has to be warm. leave it in park on a flat surface, with it running check the dipstick. should be in the crosshatch or High/low area. if its low, add fluid via the dipstick tube
CorollaULEV
30
08-09-2021 08:11 PM
MAXSE5SPD
08-23-2015 12:06 PM
