Clutch going bad?
Old Jan 9, 2014 | 07:42 AM
NAS's Avatar
NAS
Clutch going bad?
Usually having the pedal all the way out would mean that its going bad, or if it revs when floored but dosnt accelerate... well the past two days I have been having the opposite, have to put the pedal to the floor to disengage/engage. There is about 3-4 inches of pedal travel before it does anything. Car has 90k on it and the clutch has really got some wear the last 3 years. Other thought was clutch fluid and I will check that although I dont remember if/where the reservoir is..
Old Jan 9, 2014 | 07:48 AM
matts95max's Avatar
The reservoir is in the top right corner of the engine bay. It sounds like you should check your fluid. If its low, you may need to find the leak. Once you add fluid (if its low), pump the clutch a good bit and it should stiffen up. If it does not, you may need to bleed the line.
Old Jan 9, 2014 | 08:46 AM
NAS's Avatar
NAS
Fluid was basically gone, filled it up guess ill see if thats all it takes.
Old Jan 9, 2014 | 11:30 AM
Slamrod's Avatar
You have a leak, likely in the clutch line near or at the slave cylinder.
Look into getting a SS braided 1 piece line.
Old Jan 10, 2014 | 07:54 AM
NAS's Avatar
NAS
Spent the evening bleeding the clutch and found the leak area, not sure what the black rubber hose with brase fittings on either end is called but that seems to be the source.
Size:  119.3 KBName:  20140109_172437_zps12630777.jpg
Size:  115.3 KBName:  20140109_172502_zps70182664.jpg
Size:  113.3 KBName:  20140109_172448_zps93a68973.jpg
Old Jan 10, 2014 | 09:29 AM
Slamrod's Avatar
Thats a section of your clutch line. Get the 1 piece stainless steel line, its like $40 or so and replaces the leaking section, as well as the maze of hard lines and junction boxes between the slave and master cylinders.
I had the same problem in pretty much the same spot. No sense in paying nissan out the **** for a poor OEM design when you can get a stainless line thats better in literally every aspect for cheap.
Just make sure you get the one piece (slave to master) and not the half piece (slave to junction). Both work but the one piece is simply easier to deal with and makes more sense imo.
Old Jan 10, 2014 | 09:49 AM
NAS's Avatar
NAS
Any sudgestion on length and I assume any braded line would work just like braded brake lines. If I understand it would get rid of the maze of hard ines and rubber lines with a single line from the master to basically the bleeder.
user 11122324
42
Jul 18, 2022 03:35 PM
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
