Rear wheel bearing replacment
Old Jan 15, 2014 | 02:07 PM
Patm-a32's Avatar
Hey guys ihave a nasty wheel hum in the rear passenger side, the tires all visually check out, and have been rotated nothing solves my problem my last culprit i can think of is the bearing & hub. Anyone know of a good brand of bearing and hub if i can get them together possibly so i dont have to get them pressed in and out, and how i would go about changing these bearings. Thanks
Old Jan 15, 2014 | 02:24 PM
asand1's Avatar
AFAIK, you can't buy the bearing separate anyway. CHeck around online, but be sure to check rockauto too.
Old Jan 15, 2014 | 02:39 PM
ACee's Avatar
I might have a couple brand new hubs I bought and didn't need if your interested.
Old Jan 15, 2014 | 02:45 PM
Patm-a32's Avatar
Is it as much of a ***** to replace them like the fronts are? Im looking to do the labor, i dont have 4-5 hundred to spend on labor
Old Jan 15, 2014 | 02:46 PM
ACee's Avatar
Not sure if its the right part no. For 4th gen. If you can check the part number, then they might work.
http://rs993.pbsrc.com/albums/af58/a...0?t=1389825808
http://rs993.pbsrc.com/albums/af58/a...0?t=1389825805
Old Jan 15, 2014 | 02:51 PM
ACee's Avatar
http://rs993.pbsrc.com/albums/af58/a...0?t=1389826113
Part number I got. Again, not sure if right part no. As I bought these thinking they would fit 5th gen, but I needed the ones with the abs sprocket and these do not have the abs sprocket.
Old Jan 15, 2014 | 03:08 PM
Patm-a32's Avatar
Is it hard to do them?
Old Jan 15, 2014 | 03:19 PM
ACee's Avatar
Nope. Very easy. Just check to make sure you don't need to replace that spindle nut too. If you do, then you need one of those too.
Old Jan 15, 2014 | 04:30 PM
Patm-a32's Avatar
So how would i replace them ive never done bearings
Old Jan 15, 2014 | 04:55 PM
ACee's Avatar
You replace the entire hub. Car on jackstands. Remove wheel. Remove brake. Remove spindle nut. Remove rotor. Remove wheel hub with bearing. Reverse to put back together.
I am pretty sure there is info on you tube if you want to see it done. If you were in tn I would help you out.
Old Jan 15, 2014 | 05:05 PM
Turbobink's Avatar
Agreed ... Not a bad job at all.
If you totally take your time and move at a fairly leisurely pace you can get them both done in a half a Saturday.
Old Jan 16, 2014 | 07:57 AM
Max_Gator's Avatar
I need to do this too. So, the rear hubs come with bearings in them? Unlike the fronts which must be pressed in?
Old Jan 16, 2014 | 08:50 AM
ACee's Avatar
Yup. I bought mine that way.
Old Jan 16, 2014 | 09:27 AM
Patm-a32's Avatar
am i better off aftermarket or oem i want the cheapest way, and i dont want to go through nissan parts. I am doing the labor myself just need the parts... any sugestions
Old Jan 16, 2014 | 11:00 AM
slfalco's Avatar
Might want to inspect the splash shields too, if they are rotted through then replace them at the same time.... I had rotted shields which eventually allowed salt/water to damage the bearings, ended up replacing both...
Old Jan 16, 2014 | 11:03 AM
ACee's Avatar
I went aftermarket.
Old Jan 16, 2014 | 11:58 AM
Turbobink's Avatar
In all honesty, I think if you spend some time doing some research your gonna find that the parts you pay a premium for at the dealer parts counter are manufactured by the same entities that manufacture the parts store items. There may be some specification differences, but not much.
I typically have no issue purchasing an aftermarket item but paying attention to the warranty included ... LLT is a good thing.
Old Jan 17, 2014 | 07:17 PM
Trini Boom's Avatar
This is not true right??
Huttig2009
Sep 25, 2015 03:31 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
