96 maxima water pump broken bolts/ what to do.
Old Jan 31, 2014 | 03:22 PM
ggutshall87's Avatar
I have been trying to change the water pump in my father's car for the past 1.5 weeks. Road block after road block. Whilst trying to remove the water pump, I foolishly broke two of the bolts out. One of the ears broke off as well. Finally, I was able to remove the water pump by prying. One of the bolts (top one) broke flush and the other one (left bottom) is sticking out about a quarter inch. I have tried everything I could just to fail at removing that one. I don't even know where to start with the other. In big trouble with this. Here are my questions:
Is there any way that one bolt can hold the water pump in place? One bolt for holding it in while the broken bolt that sticks out can be extra support to keep it from rotating any.
If i get (somehow) the protruding quarter inch broken bolt out, can two bolts hold and support the water pump?
Any other ideas could help.
Old Jan 31, 2014 | 03:26 PM
njmaxseltd's Avatar
The pump needs all it's hold down points torqued correctly so it doesn't leak.
You must get the broken bolts out, either drill or ez out. Either way, they must come out and new bolts put in.
Old Jan 31, 2014 | 03:37 PM
I have tried to use easy outs but they just can't drill into the bolt enough. Is there a way to get the housing to the water pump ie the cylindrical hole the pump goes into, out of the car? I noticed there are a few bolts around it. Do those bolts hold it in?
I bought a 90 degree drill attachment just for this purpose. I just can't use drill bits in it unless they are quick release and small enough.
Old Jan 31, 2014 | 04:11 PM
Dhione's Avatar
well the water pump mounts to the inner timing cover behind the outer one witch you are looking at to remove both of those covers is a pain to do with the engine in the car. I would try to make a little nick in the bolts and then try to tap it out with a flat head and a hammer. that has worked for me with other things.
Old Jan 31, 2014 | 04:40 PM
Thank you for your help. That may work for the protruding bolt but the upper bolt can not even be seen, so I don't know if that will be possible for that. I will certainly try though. Thank you.
Old Feb 2, 2014 | 12:54 PM
6cyl-97maxima's Avatar
+1 for attempting to deal with the upper bolt. As far as the lower bolt that is broken flush its a little more tricky. The proper way is to drill out the entire broken bolt, using a mildy oversized drill bit then re-thread the hole to accept a new bolt. You could Try drilling into the broken bolt just big enough to accept a self taping screw, which would have something on the threads to lock it in place (or tack weld it), if it were sticking out more I would say weld a l bolt head to it and back it out normally with a scocket wrench.
Old Feb 2, 2014 | 04:28 PM
CMax03's Avatar
It's can be done!
Old Feb 3, 2014 | 06:22 AM
Originally Posted by CMax03
It's can be done!
^^^ ??? Do you mean it can't be done. As in my idea wont work? Or did you mean something entirely different.
Old Jun 2, 2022 | 07:33 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Reinstall original pump with new O rings and call it a day.
Old Jun 2, 2022 | 08:47 PM
JvG's Avatar
JvG
This post is over 8 years old.
Old Jun 3, 2022 | 12:13 PM
Bad *** Newb
dumb *** website listed this thread right below the current one. Pisses me off.
I ****ing deleted this and reposted...only to get ****ed right back in the same thread.
Old Apr 4, 2023 | 11:11 AM
4evaStewdent's Avatar
What if the inner timing cover has been stripped? Do I add a bigger boat or how does that work?
EP95SE
20
Mar 4, 2018 01:47 PM
Young Guy
19
Jan 6, 2014 07:16 AM
speed racer
67
May 24, 2011 12:37 PM
battlestylespl
May 25, 2009 09:56 AM
prjctMAX
27
May 27, 2006 10:00 AM
