driver side healight problem maxima 1997
Old Feb 7, 2014 | 02:38 PM
beboski's Avatar
my driver side headlight is recieving voltage from two wires at the same time instead of tru one this is making the hi beam be on all the time while the other one is working normal and the hi beam light on the dash is always on little help please
Old Feb 7, 2014 | 05:06 PM
6cyl-97maxima's Avatar
Guessing that you have a bad relay.
Old Feb 7, 2014 | 06:11 PM
beboski's Avatar
thats on the engine compartment rite
Old Feb 8, 2014 | 07:21 AM
Its under one of the pannles in the engine compartment that houses the relays and fuses. I will ho take a look. In a little bit to locate the high beam and low beam relay and report back to you.
My best guess would be that the hi / low beam relay has become stuck in the high beam position. If it turns out the relay is good, that my next step would be to have you check the wiring in order to make sure that the high beam negative wire is not grounding out somewhere sending power to the supply power wire for the hi beam.
I'll let you know soon
Nathan
Old Feb 8, 2014 | 03:03 PM
After a quick look it would appear that the relay in in the box located at the front of the engine bay on the passenger side, right in front of the power steering resivior. The relay is labeled "lamp". I believe this is the suspect relay. However I have to check the wiring diagrams to know for sure.
Old Feb 9, 2014 | 09:23 AM
CMax03's Avatar
Sounds like a light switch/stalk problem....
Old Feb 9, 2014 | 02:41 PM
DennisMik's Avatar
First of all, there is no relay in the headlight circuit. There is a relay that will flash the headlights if the alarm goes off, but that would cause both headlights to be on.
The problem could be a bulb where the filaments are touching inside the lamp. It could also be the headlight switch.
Old Feb 9, 2014 | 08:06 PM
My bad sorry guys. By no means did I want to give out misinformation. I really did think that the relay or whatever it is, marked "lamp" was a hi beam low beam relay.
Again sorry.
fastcarny
May 18, 2020 10:40 AM
Samedi
Aug 13, 2015 04:05 PM
erniel
Aug 8, 2015 09:32 AM
dauntlessmax
Aug 5, 2015 10:29 AM
BassAddictJ
Aug 4, 2015 11:38 AM
