Use gasket sealant when replacing valve cover gaskets?
Old Mar 5, 2014 | 02:14 PM
njmaxseltd's Avatar
Old Mar 5, 2014 | 02:33 PM
Nissanserguy's Avatar
Are you asking in conjunction with valve cover gaskets or all by it self?
I have done it on my old tsi and it never leaked, just cleaned the mating surfaces real good before applying.
Old Mar 5, 2014 | 02:41 PM
Fakie J Farkerton's Avatar
Originally Posted by njmaxseltd
Old Mar 5, 2014 | 03:51 PM
njmaxseltd's Avatar
Along with, I've got the Felpro rubber set.
Old Mar 5, 2014 | 03:55 PM
Climaxx's Avatar
Originally Posted by Fakie J Farkerton
This
Old Mar 5, 2014 | 03:56 PM
Assuming you're using the red high temp rtv.. I would say you're good to go.
No worries on leaks. Doing mine soon, well the front, and I'll be using the Felpro and RTV.
Old Mar 5, 2014 | 04:24 PM
TurboA32's Avatar
Yes you have to use liquid gasket when replacing the valve cover gasket. The factory service manual tells you to use it so yes. If your facing the engine in the top and bottom left corners you will put it there. You will see a space on the gasket for it on both rear and front valve cover gaskets. Use the Grey RTV liquid gasket.
Old Mar 5, 2014 | 04:30 PM
ACee's Avatar
Old Mar 5, 2014 | 05:30 PM
njmaxseltd's Avatar
Thank you.
Old Mar 5, 2014 | 06:06 PM
nsnrider's Avatar
Originally Posted by turboa32
yes you have to use liquid gasket when replacing the valve cover gasket. The factory service manual tells you to use it so yes. If your facing the engine in the top and bottom left corners you will put it there. You will see a space on the gasket for it on both rear and front valve cover gaskets. Use the grey rtv liquid gasket.
+1
Old Mar 5, 2014 | 06:45 PM
CS_AR's Avatar
Originally Posted by nsnrider
+1
+1 Permatex Ultra Grey
Old Mar 5, 2014 | 07:01 PM
Quickywd01's Avatar
Grey stuff and in the corners.
Old Mar 5, 2014 | 09:30 PM
jholley's Avatar
To keep those new gaskets from leaking apply the sealant to both sides of the rubber gasket where they sit on the rocker cover and cylinder heads. Along with the left corners apply a few tiny tabs of sealant on the right side of the rocker covers groove to keep the gaskets from falling off when you flip them over to mount on the heads. After inserting the gaskets onto the covers let them sit for 15 minutes for the sealant to dry.
Apply to the left corners again onto the bottom side of the gaskets where they mount onto the heads.
When I first fixed this oil leak I only applied sealant to the rocker covers groove and they leaked again within 1,000 miles. I applied to both sides 14,000 miles ago and they haven't leaked since.
Old Mar 6, 2014 | 04:00 AM
ACee's Avatar
^ spoon fed
Old Mar 6, 2014 | 05:09 AM
max ride 41's Avatar
Thank you.
well, considering i used the black rtv and it started leaking again a year later i'd say grey as well. i used fel-pro as well.
Old Mar 6, 2014 | 07:51 PM
I used red on three different motors, no leaks. but hey, to each his own.
Matt93SE
Apr 8, 2018 09:23 AM
FlaMark
25
Aug 28, 2015 10:15 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Nintensity
Aug 13, 2015 05:41 PM
