Alignment issue ?
Old 04-04-2014, 05:39 AM
Patm-a32's Avatar
Alignment issue ?
So my cars steering seems pretty messed uP.. Under acceleration and braking the wheel is straight and im moving perfectly straight with no pull to either side, as soon as i let off the acceleration or brake (easier to see driving with no hands on the wheel) as soon as im not accelerating or braking my steering wheel goes to the left and it will pull to the left ... And then as soon as brake or accelerator is touched the wheel goes back to normal position and travels straight as an arrow, can this be my allignment ? Lots of potholes in my area thats why i believe it to be allignment. I have new inner/outer torods, new struts(coils, shocks, bearings mounts). Both axels new, both bearings and hubs
New, new tires balanced and mounted.. Hoping just an allignment
Patm-a32 is offline
Old 04-04-2014, 05:44 AM
Patm-a32's Avatar
**btw i just put on my 18" summer wheels, switched from 16" winter beater wheels, last allignment was about 3 months ago (8-10kmiles) allignment was done with 16" wheels on idk if i should get an allignment after putting bigger wheels on, cause i didnt notice the issue with the 16"s
Patm-a32 is offline
Old 04-04-2014, 07:01 AM
njmaxseltd's Avatar
Lose components, check the entire front end, replace anything that's in need or repair and have the car aligned.
njmaxseltd is offline
Old 04-04-2014, 07:05 AM
Patm-a32's Avatar
Ive already replaced everything in the front suspension with in the last 20k everything but the rack and pinion but that checks out okay
Patm-a32 is offline
Old 04-04-2014, 07:28 AM
Maxima 97 SE's Avatar
Replace your rack and pinion bushings. There's two bushings that hold it in place and that play a major role in keeping the steering straight. Then also replace your sway bar bushings. That is also going to help.
Maxima 97 SE is offline
Old 04-04-2014, 07:31 AM
Patm-a32's Avatar
Sway bar is set i just did es bushings in the sway bar along with new end links. Is the rack and pinion bushings something i can do at home ?.. Or is it a pain
Patm-a32 is offline
Old 04-04-2014, 07:55 AM
cashoit's Avatar
could it be a frozen caliper?
cashoit is offline
Old 04-04-2014, 08:09 AM
Here what I did. The rack and pinion bushings keep the rack and pinion from moving around and keep it in place. The driver side one easy to do but I didn't do it as I had someone else do it. But the passenger side is the hard one as its above the exhaust or catalytic converter. But replace the passenger one as that was the one that made the biggest difference out of any of the bushings. The passenger side I would probably say is ok.
Old 04-04-2014, 08:18 AM
Patm-a32's Avatar
I would do both.. Any idea how much in labor i would pay for this? I dont like messing with things i dont know. Ive done the rest of the suspension components in my driveway i just dont know much aboht the rack and pinion
Patm-a32 is offline
Old 04-04-2014, 08:20 AM
Fakie J Farkerton's Avatar
It's all just nuts and bolts mang.
You can do it!
FSM to the rescue!
Fakie J Farkerton is offline
Old 04-04-2014, 08:28 AM
I paid 40 bucks for the driver side. But it all depends on the mechanic you find.
Old 04-04-2014, 11:53 AM
deathwobble's Avatar
Was the car doing thus before you swaped wheels and tires?
Edit. I see you said you didn't notice and pulling with the 16s. Try swapping the front tires side to side and go drive it. Sometimes the radial belt can move in the tire causeing a radial pull. If it is the tire,swapping it will make that car pull the opposite direction. If it dose then you have a funky tire
deathwobble is offline
Old 04-04-2014, 07:24 PM
Patm-a32's Avatar
It might have been doing it with the 16s but if it was it is much more noticable now I'll try that out tomorow. The passenger side tires valve stem leeks about 10psi every 2 or so days so thats my first shot the uneven pressure in the front causing to pull
Patm-a32 is offline
Old 04-05-2014, 12:01 PM
Patm-a32's Avatar
so it was the air in the tire, now my car just pulls to the right all the time. So just time for allignment
Patm-a32 is offline
Old 04-05-2014, 02:58 PM
asand1's Avatar
Lower control arm bushings are shot. Probably on the passenger side from leaking power steering and rear valve cover leaking oil.
asand1 is offline
Old 04-05-2014, 04:35 PM
awesome glad you got it figured out! Make sure whoever does the alignment shakes everything down. No point in doing an alignment if anything has play in it
alahjahwan09
18
09-21-2015 09:12 PM
Bonka
09-14-2015 11:18 PM
bbsitum
09-11-2015 04:55 PM
dcam0326
09-08-2015 11:02 PM
Quick Reply: Alignment issue ?
