Rear suspension trashed (not struts)
Old May 4, 2014 | 05:57 PM
arcticracer's Avatar
A rough season of dirt racing finished off my rear suspension so now looking for upgrade options. Anyone know if the mounting ears are better or worse from year to year or model?
Old May 5, 2014 | 05:38 AM
njmaxseltd's Avatar
Never seen that before. Years are the same as far as quality goes.
You need a new rear beam.
Old May 5, 2014 | 07:03 AM
Patm-a32's Avatar
thats going to need a whole new beam not just the lateral link and control rod ... Ouch
Old May 5, 2014 | 08:54 PM
Trini Boom's Avatar
+1. Never seen this happen. Get a replacement beam and spray some rust reformer on it before installing. That rim doesn't look like it faired too good either.
Old May 6, 2014 | 05:41 AM
asand1's Avatar
https://maxima.org/showthread.php?t=632039
Old May 6, 2014 | 06:25 AM
CS_AR's Avatar
Originally Posted by asand1
Thanks for the link. Very interesting!
Old May 6, 2014 | 11:20 AM
I can only dream of doing that upgrade as I really wrestle with understeer. So for now I will just strip the parts off a wrecked car.
Old May 6, 2014 | 10:17 PM
CMax03's Avatar
plenty in the boneyard now!
Old May 6, 2014 | 11:53 PM
dwapenyi's Avatar
Is it really an upgrade, though? What alot of people on the org don't realize is that the rear multi-link beam suspension has an RSB built into the beam. When you add an aftermarket RSB you effectively have 2 RSBs.
For example in the pic of the Sentra before and after the Panhard install, the 1st pic says "Without the Panhard, using the OEM SRL", when it should "Without the Panhard, using the OEM SRL PLUS OEM RSB PLUS AFTERMARKET RSB"
The aftermarket RSB is plainly obvious in the picture. Given that setup, rear end lift as the result of 2 RSBs is inevitable.
In the after setup the SRL, captioned "With the Panhard" really is "With the Panhard PLUS OEM RSB." So now you have the OEM RSB working in conjunction with the Panhard rod..... with good results.
I had an RSB on my car but once I lowered it the RSB wasn't needed. I found the tail end of my car to be too hot with H&Rs and an aftermarket RSB. The Panhard article seems to bear out this observation.
Huttig2009
Sep 25, 2015 03:31 PM
AcuraLegend
Sep 22, 2015 04:22 PM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
george__
Aug 18, 2015 07:06 PM
