WTF did I do *_*?
Old May 8, 2014 | 09:33 PM
george__'s Avatar
WTF did I do *_*?
So..
- Parked the car in revere
- Turned car off with steering wheel somewhat to the right
- Key won't come out
- I can start and turn off the car, radio works etc but the key won't come out
I'm scared to play with the key too much because if it breaks then I'm in even bigger sh*t
Did I activate a security feature?
Please advise.
Old May 8, 2014 | 09:40 PM
asand1's Avatar
Start the car, straighten the wheel, and put in park. The key wont go to "lock" in anything but park. This is a safety feature thas been mandated and in use since the '80s
Old May 8, 2014 | 09:50 PM
max ride 41's Avatar
please george never move over the the us, thanks
Old May 8, 2014 | 09:54 PM
george__'s Avatar
I tried taking it around the block and turned it off with the steering wheel facing straight but still it is stuck.
ffs
Old May 8, 2014 | 10:08 PM
george__'s Avatar
-_-" doh
Old May 8, 2014 | 10:12 PM
Fakie J Farkerton's Avatar
User error George?
tosheto's Avatar
Is your gear shifter on Park?
Old May 8, 2014 | 10:29 PM
george__'s Avatar
Yes it is. I just disconnected the battery so car won't die but what the f8kkk
Old May 8, 2014 | 10:49 PM
bumpypickle's Avatar
Try giving it a violent jiggle back and forth. I've had this happen to friends of mine numerous Amounts of times.
Old May 8, 2014 | 10:53 PM
96i30azn's Avatar
Why in the world would you have to d/c the battery if your key goes to lock? Well maybe you broke something in the lock cylinder or something got stuck. Wiggle the key and see if it'll come out.
For now, pull the fuel pump and starter fuses and lock your car with another key so nobody steals your broken car.
Old May 8, 2014 | 11:11 PM
george__'s Avatar
It only wants to move between lock and start. Can't move it to lock -_-"
Old May 9, 2014 | 12:32 AM
george__'s Avatar
It is the gear box. Drove around the block and aggressively moved the car into park and the key came out
Old May 9, 2014 | 02:00 AM
asand1's Avatar
Correction, it is the interlock mechanism in the shifter/lock cylinder. Do not shut off in gear/neutral, only in park.
Old May 9, 2014 | 04:01 AM
BobPezz's Avatar
Old May 9, 2014 | 04:11 AM
dwapenyi's Avatar
Make sure you have the brake pedal pushed too.
Old May 9, 2014 | 04:36 AM
ac max 92's Avatar
The old school like the 3rd gens have the push button on the ignition to release the key which I guess wasn't a bad thing. Maybe your car wanted you to leave the key for easy access to share with the neighborhood as a grocery getter
Old May 9, 2014 | 04:42 AM
ac max 92's Avatar
[QUOTE=max ride 41;8949822]please george never move over the the us, thanks[/QUOTE
The US is a big place im sure there's already enough crazy there are you sure you don't want to adopt a George to add to the equation lol. There's crazy all over im sure George in the US would be the least of worries
Old May 9, 2014 | 05:58 AM
[QUOTE=ac max 92;8949872]
what??? no!!!! no breeding george, please
Old May 9, 2014 | 10:25 AM
george__'s Avatar
[QUOTE=max ride 41;8949883]
wtf?
Old May 9, 2014 | 02:52 PM
CMax03's Avatar
Turn slightly to right somemore and push the release button.....
Old May 9, 2014 | 02:58 PM
Solved.
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
CIRCO
Mar 1, 2001 07:26 PM
yongjun
Jan 20, 2001 08:42 PM
