Replaced Upper Oil Pan Seal - No start after?
Old Jul 9, 2014 | 04:19 PM
Alaskus's Avatar
I have been working on my upper oil pan leak the last couple days (wasnt that bad of a job)
I followed the write up: http://forums.maxima.org/4th-generat...n-removal.html
No major problems along the way except; I broke the tensioner bolt, and the lower oil pan leaked. Both were easy fixes.
Now I have everything back together and I'm getting no start, and (to my untrained ear) what sounds like a metal-on-metal noise.
I dont want to keep hunting "possible" issues and potentially make any simple error into a serious problem.
The only ideas I have:
--- I damaged one or both of the CKPS sensors which could affect start (all I did was remove, place in plastic bags, and hang them in the shed till I reinstalled).
--- Belt tension is wrong? would this even cause a no start issue?
--- only put in 3.5 quarts of oil, which I think is low, as having had both the pans off. This might account for the metal noise, but not the no-start.
Anyone run into a similar experience or have some advice?
Old Jul 9, 2014 | 04:26 PM
CS_AR's Avatar
Are the sensor plugs in good shape? Can you post a video with the noise?
Any blown or disconnected fuses like the fuel pump?
I had mine all torn apart then put it back together and it started up.
Old Jul 9, 2014 | 04:29 PM
Alaskus's Avatar
Ill check the fuses and get a video when i have a second set of hands.
...fuses are good.
Here is a video
http://www.youtube.com/watch?v=rNgRAfmBJkQ
Old Jul 10, 2014 | 08:07 PM
Alaskus's Avatar
wow... fixed it. was getting an p0340 code. swapped three different cam sensors and one CKPS (REF) i finally jacked up the car to look at the CKPS (POS). i manage to put the little metal shim on under the sensor versus over it. and thats all it took. car starts!
Old Jul 10, 2014 | 08:30 PM
Fakie J Farkerton's Avatar
I did the same thing after a clutch install.
Old Jul 11, 2014 | 06:38 PM
Alaskus's Avatar
...not being the only one makes me feel better. Thank you.
Old Jul 11, 2014 | 06:53 PM
No problem.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
maxinout93
Aug 20, 2015 02:17 AM
Balkins
Aug 12, 2015 06:39 AM
maxima297
Aug 3, 2015 12:50 PM
