questions...
Old Jan 23, 2002 | 08:23 AM
A5295's Avatar
questions...
I have a couple of questions. My shifter is like stiffer than normal when i shift, and i cannot figure out why. Any ideas? I also need to findout where to get my headlights buffed-they are going yellow on me. Can i do that myself? If so, I wouls like to be pointed to some directions as well. thanks everybody
Old Jan 23, 2002 | 08:31 AM
njmaxseltd's Avatar
I can't help you out with the shifter. Maybe a gear oil change will help you out. As far as headlights go. My buddy had a Cougar that had "yellow" headlights. The lenses were really bad. I used a high speed buffer and some agressive compond on them. They came up beautiful. Nice and clear. You may try it by hand using the strongest compond off the shelf. Turtle wax? The heavy duty stuff. A high speed buffer generates heat and heat is your friend when buffing out things like that. Just don't do this on your paint, because high speed buffing and heat are dangerous if you don't know what your doing. You'll go right through your paint down to metal before you know it.
If you dont have access to a buffer, stop by your local body shop and ask if they can hit them really quick for ya. Tip the guy a 20 and your all set.
mpc578
Jan 2, 2004 10:51 AM
kaniksu
Jan 1, 2004 02:32 AM
MAXRAY
Aug 2, 2002 11:59 AM
ejj
Jun 20, 2002 02:46 PM
hoey
Apr 4, 2001 01:09 AM
