resoldering speedometer PCB
Old Oct 31, 2014 | 10:37 PM
adeste's Avatar
resoldering speedometer PCB for CC fix
I have been having problems with my cruise control working intermittently and I have a VSS error code. After doing some research, I have determined that I need to resolder my speedometer PCB board. I have seen others stress that the the hole circled in red needs be be soldered but what about the other holes circled in yellow?
I will let you know if this solves my cruise control and VSS problems.
Old Oct 31, 2014 | 10:51 PM
DennisMik's Avatar
The speedometer cluster will not cause a VSS error. The VSS is in the transmission and feeds the speedometer and the cruise control. Fix the VSS problem and the cruise control will work.
Old Nov 1, 2014 | 08:06 AM
adeste's Avatar
I've read on several threads here that bad solder joints and loose mounting screws cause a VSS CEL and thus causes the CC to stop working.
Old Nov 1, 2014 | 10:00 AM
JvG's Avatar
JvG
I had no cruise control and a vss related cel. I replaced the vss, that did not fix the problem. I resoldered all four of the spots the first poster circled. The repair did solve the cel code. I still have no cruise.
Old Nov 1, 2014 | 11:54 AM
When your CC stopped working, did your speedo stop working too?
https://maxima.org/forums/4th-genera...peedo-cel.html
Old Nov 1, 2014 | 01:49 PM
adeste's Avatar
Speedo always worked, but the CC would work intermittently and now it does not work at all.
I recently replaced my transmission and the new one came with a VSS, so I figured that a bad speedo connection was throwing the CEL.
In that thread, smai555 recommended resoldering the speedo, which solved the CC and VSS problem. However, I can not tell if the screws that I circled in my picture are soldered in his.
Old Nov 1, 2014 | 05:18 PM
schmellyfart's Avatar
The contacts marked with a green box are what needs to be resoldered.
Old Nov 2, 2014 | 03:33 PM
CS_AR's Avatar
Thanks for posting the circuit board with re-solder locations.
Old Nov 3, 2014 | 05:34 PM
adeste's Avatar
CC fixed
After resoldering the contacts marked with a green box and red circle my CC is now working.
Old Nov 3, 2014 | 07:28 PM
Hmmmm maybe I should give this a try on my brother's car.
MR2 T'd
Jul 9, 2021 05:06 AM
jchronis2552
Sep 21, 2015 05:52 AM
Djsmaxima
Sep 14, 2015 11:58 PM
fornimage
Feb 10, 2001 12:28 PM
