Help please - car overheating
Old Dec 12, 2014 | 11:22 PM
Newmaxima2014's Avatar
Over heating
Ok, so my car use to over heat when I was going over 75mph! So I changed the thermastat last weekend also there was a new water pump put in last year. No coolant leaking in the oil. But I still over hear only now I'll over heat after driving around for a hour at like 45mph. I flushed radiator out clean. Im about to go buy a new raditor tomorrow. Also I can not get my ac or heat to work they only come on when they want to any ideas please?
Old Dec 13, 2014 | 01:32 AM
Have you confirmed that your fans kick on? Have you confirmed you don't have any air in the system by burping it?
Typically no heat means bad water pump or clogged heater core.
Have you searched? Have you read the few overheating threads here on page 1 and 2?
Old Dec 13, 2014 | 03:00 AM
Here's one of the recent threads. Turned out to be a bad water pump.
https://maxima.org/forums/4th-genera...erheating.html
Old Dec 13, 2014 | 07:10 AM
Thank you so much
Yes I spent all night reading threads! Lol I love this site! But, yes checked the fans they come on after letting car sit for 35 min. But it will blow heat and cold but only when the car wants to. No I will try burping it today. I did how ever take off raditor cap nd started car seem that it working fine
Old Dec 13, 2014 | 01:02 PM
CMax03's Avatar
Did you check the to make sure you don't have a hose collapsing? How about running it w/o a thermostat to see if it overheats? How about checking to make sure your fans are fully attached to the fan motors output shaft if the motors get to hot they have been known to melt the plastic causing the fan to actually slip and not turn fast enough nor pull a suffiicient amount of air thru the radiator....but visually to the eye it's appears to be turning...
Old Dec 13, 2014 | 02:03 PM
DennisMik's Avatar
Originally Posted by Newmaxima2014
Over heating
You probably have a combination of 2 things.
One hose hot and one hose cold indicates a thermostat that isn't opening up. On these cars, only use a Nissan thermostat. All other brands have a tendency to not work properly.
Another thing is that these cars tend to trap air in the engine. You need to either park the car on an incline with the nose up or get the car on some ramps so that the nose is up. Then run the engine with the radiator cap off until the thermostat opens up and the air pockets burble out. Be careful because the air will shoot coolant out the open filler neck if the radiator is real full. Once the air is out, fill the radiator completely and put the cap on.
And please... DO NOT be making multiple posts. This is the 3rd post on this that I have found.
Old Dec 14, 2014 | 04:17 PM
sorry
Ok thank you I WONT keep postibg
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
Gsantos79
Aug 8, 2015 07:41 AM
