97 max been sitting for a while...
Old Jan 2, 2015 | 07:41 AM
rellrealist's Avatar
Gotta 97 max that has been sitting for a year. I'm sure the battery is dead. It has 270xxx miles on it but the last time I started it it started right up. Car hasn't been inspected since 2010 I got it from the auction March of 2014. But my question is what should I do to get it drive able . Such *** fluids and what certain checkups should I be looking for. I also have a broken hose on my air flow thingy...
Attached Thumbnails 97 max been sitting for a while...-forumrunner_20150102_104033.jpg   97 max been sitting for a while...-forumrunner_20150102_104046.jpg   97 max been sitting for a while...-forumrunner_20150102_104058.jpg
Old Jan 2, 2015 | 08:44 AM
Fakie J Farkerton's Avatar
Fix the hose and change the oil.
Double check all other fluid levels and put the battery on a charger.
Watch out for flat spots on your tires if you didn't over inflate them before/during storage.
It's likely the gas is bad too unless you used stabilizer.
Old Jan 2, 2015 | 12:30 PM
DennisMik's Avatar
Definitely use fresh engine oil and filter before starting the car. I would add some engine cleaning stuff such as Risoline to the oil and then change the oil after maybe a 1000 miles.
If you need power steering fluid, these cars use Dexron III auto trans fluid, not whatever standard power steering fluid is.
Once the car is running and everything seems to be fine, flush the cooling system and add fresh antifreeze.
Old Jan 3, 2015 | 03:19 AM
97_GXE's Avatar
My Max sat in a garage for awhile...not sure how long, before I bought it. The issues I was having was it being hard to start especially on low fuel. Even now, when I get too low on fuel it can be tough.
My first car was also an old rusty Buick that sat under a tree for YEARS.
In addition to all the tips above, take it for a long road trip...use a full tank of gas to get all the old gas out. Change the fuel filter (easy to do) since all the enzymes and bacteria has multiplied in your fuel tank. Let the engine get hot for awhile to burn off oil residue that may have glued itself to the internal parts. Use Startron, BG 44k or Lucas Ethanol fuel cleaner.
Old Jan 3, 2015 | 03:22 AM
97_GXE's Avatar
Also, no diss to the above poster, but I wouldn't waste money on oil additives. Theres already additives in the top brand oils. Just a good synthetic or blend and a long drive will do. The fuel additives I mentioned would generally be to lubricate the dried out parts from the ethanol.
Old Jan 3, 2015 | 10:51 AM
Don't kno y pics aren't loading...
There is one obvious broken hose and another hose that I can't seem to find what it belongs too or were it comes from
Old Jan 3, 2015 | 10:58 AM
jholley's Avatar
If you're referring to the hose near the AT dipstick then it's the AT breather hose that doesn't connect to anything.
Your photo is not detailing any specific hose so I don't know if this answers your question?
Old Jan 3, 2015 | 11:02 AM
Maybe it is... when the car was running I never seen any fluids leaking out of it... it comes up right between the mass air flow sensor and the engine block
Old Jan 3, 2015 | 11:05 AM
jholley's Avatar
That's the location of the AT breather hose that doesn't have any top connection.
As earlier stated install a charged battery, change your oil, filter, gas... and check all other fluid levels.
Old Jan 3, 2015 | 11:10 AM
JoshG's Avatar
damn no wonder why its been sitting, 270k miles is quite alooot of miles lol. but get that bad-boy running again and see if u can get it to run again... just listen to what they are saying.
Old Jan 3, 2015 | 11:47 AM
Old Jan 5, 2015 | 05:05 PM
SupaMaxima's Avatar
Also, bleed your brakes while you're changing the fluids. I had mine sitting for about 1.5 years and I was barely able stop when I took it for a test drive. I overran a couple stop signs due to this.
Old Jan 6, 2015 | 01:09 AM
bumpypickle's Avatar
DONT use synthetic oil. Your car has been sitting for a while and has high mileage. It is not reccomended. Also, personally I would completley redo brakes (rotors, pads, caliper, brackets,hoses,fluid,etc.)
Old Jan 6, 2015 | 03:13 PM
CMax03's Avatar
Everyone's told you pretty good info but I would start it with the old fluids first just to see if there are any leaks then drain once you've got it pretty warm if possible! I would hate to have a really serious leak after putting new fluid in the car...But i would inspect as much as possible visually before starting and ensure any bad situations!!!
Old Jan 8, 2015 | 07:50 PM
When it ran nothing leaked or squeaked... engine sounded good... no check engine lights or anything... I'm hoping I don't have any troubles... I can tell the previous owner took pretty good care of it... I even still technically have 10000 miles left on my warranty tires... found the paper in the glove box when I bought it... hoping my taxes come fast so I can get her up n running again
Old Jan 8, 2015 | 08:59 PM
Thats good news. Have fun working on it. I enjoy a good w.i.p.
Old Jan 8, 2015 | 10:39 PM
JoshG's Avatar
interesting to see it only sat a year and runs fine afterwards
Old Jan 9, 2015 | 03:06 AM
asand1's Avatar
I can see the hose with the broken nipple you are referring to. It is part of the PCV system, and needs to be fixed. You will rev high with a vacuum leak and lean condition if not fixed.
Old Jan 9, 2015 | 10:16 AM
JoshG's Avatar
^ should circle the location in the picture. would help others as well
Old Jan 9, 2015 | 04:05 PM
asand1's Avatar
Done
Old Jan 12, 2015 | 09:27 AM
Will it be ok with a quick fix like glue or do I need to replace the entire black box from a junk yard or something new
Old Jan 12, 2015 | 09:32 AM
Can u tell me the name of that part so that I could look it up
Old Jan 12, 2015 | 09:46 AM
It's a hemholtz resonator.
Best bet is the junkyard, but for a quick temporary fix I don't see anything wrong with cleaning it up well and adding the best stuff for every toolbox...duct tape.
Old Jan 12, 2015 | 03:43 PM
JEB Davis's Avatar
My 98 SE had the same plastic nipple broken when I bought it. I glued it with epoxy and it's holding just fine after about 3 weeks of driving in sometimes -10 degree weather. When/if the glue gives up on me, I will do something more permanent!
Old Jan 12, 2015 | 09:46 PM
Cool thanks for all the help guys
Old Jan 12, 2015 | 10:11 PM
DennisMik's Avatar
Wow! All we need now is for planecrash to tell us exactly how much horepower that adds... or is it takes away?
Old Jan 13, 2015 | 12:03 AM
What did I do?
I didn't say use duct, just duck tape.
Old Jan 13, 2015 | 12:42 AM
not sure where you live but junkyard is best. Around me, there are 3 or 4 junkyards that have at least 3 4th gens in each yard. Also if your doing oil changes yourself id reccomend buying a new drain bolt off rock auto or any other parts store. good to have a fresh unrounded bolt w/ new seal
Old Jan 13, 2015 | 10:53 AM
DennisMik's Avatar
The part is called either Duct Assy-Air or just Air Duct. In the parts book, it is lookup code 16579P, part number 16576-31U17.
http://www.courtesyparts.com/16576p-...-p-128929.html
Old Jan 13, 2015 | 11:14 AM
The part is called either Duct Assy-Air or just Air Duct. In the parts book, it is lookup code 16579P, part number 16576-31U17. http://www.courtesyparts.com/16576p-...-p-128929.html
Google hemholtz resonator 95-99 maxima and see what pops up.
I hear you though.
It's good to have people that know the FSM/part numbers as well as you do, but it's known by the other name as well.
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
captchaos
Mar 15, 2016 12:18 PM
jsmith24
Feb 1, 2016 12:35 AM
ik95
Sep 16, 2015 08:11 PM
MaxLife17
Sep 8, 2015 02:36 PM
