Hard starting
Old Jan 5, 2015 | 05:55 PM
Josh_9096's Avatar
Hard starting
97 maxima hard starting. The starter will engage and it sounds like it looses power for a split second and will grind and then will work again. It also takes forever for the car to fire. And when it does, it is very flooded. It will run like crap for a couple seconds and smells like raw gas. I replaced crank sensor and temp sensor and battery. Starter tested good. I have an o2 sensor code but its been doing this before I got the code.
Old Jan 6, 2015 | 09:15 AM
njmaxseltd's Avatar
Check the positive cable connections to the starter. Make sure they are clean and tight.
Bench testing a starter isn't really proving it's able to turn your engine over. When mine started to go, it did exactly what you're describing.
97_GXE
20
Sep 17, 2015 08:12 PM
97_GXE
Sep 15, 2015 06:47 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
slowlifer
Sep 8, 2015 05:53 AM
trungg86
Sep 4, 2015 04:58 AM
