98 maxima jerking and shut off
Old Jan 26, 2015 | 11:32 PM
  #41
JLA117's Avatar
Originally Posted by theWalkinator
The OP asked questions but never take the advices, I guess the OP is not a DIYer so I think he just want to make sure that paying someone fixing his car is justified.
So all I can say is good luck.
Well guys, I did do the knock sensor and the car isn't doing what I said it was doing. It's fine now. Even I checked all the codes myself and there wasn't an 0102 which is MAF. No knock sensor code now either. Car got faster too than before. Old knock sensor was 200k miles and it's all chewed up. I did take you guys advice and cleaned the MAF. Even if I wasted my time with KS I still want my car perfect. Now one more code to clear 1302 MAP BARO SW solenoid valve. The car has rough idle now. No more new car type idle like before.
Old Jan 26, 2015 | 11:34 PM
  #42
JLA117's Avatar
And plus I did it myself. I squeezed my hands through. Just to loosen the bolt. First use an extension to loosen bolt.
Old Jan 27, 2015 | 05:03 AM
  #43
CS_AR's Avatar
Here's glad to see it worked out for you. Are you using Premium Fuel? If you are not currently using Premium, you might try it now that the KS has been replaced.
Old Jan 27, 2015 | 03:19 PM
  #44
JLA117's Avatar
Yes, I've been using premium for the last 3 pumps. I used to use 87 octane till I read the manual. I need 91. I barely got this car in October.
I still want that rough idle out of there. I'm getting p1105 with obd scanner. And when I check manually with screw driver it's 1302. Just one code.
Old Jan 27, 2015 | 03:21 PM
  #45
JLA117's Avatar
Here's info on how to determine if you Maxima was built for California.
https://maxima.org/forums/4th-genera...tml#post707273
So how do I tell if my car is Cali or Fed spec?
Raise your hood. Look for a shiny metal identification tag fastened to the passenger side of firewall. The top row is the Vehicle Identification Number, starting with J. The second row is model information. The first five characters are BLHUL. The 12th character is the destination:
N = Canada
V = California
U = US, not California
Sorry it's a "U". Not California
Old Jan 27, 2015 | 03:29 PM
  #46
JLA117's Avatar
Originally Posted by No Sparring
The same thing has been happening to me the last couple of days on my '99. I pulled the codes at Autozonoe and got P0160. Possible oxygen sensor defective or system running very rich or lean or the fuel pressure is very high/low.
I replaced the fuel filter and the problem continued a day later (last night). I also had code P0325 which is a knock sensor which would suggest low fuel pressure as well according the the code printout.
I want to know if the knock sensor really did fix this guy's car.
I'm going in later for a diagnostic.
The courtesyparts.com site offered earlier is extremely expensive= $450 for a MAF. Called NAPA and they said $250. Want to be sure i buy the right part so I'm not just replacing parts. I'm curious about everyone who said they replaced the MAF- did you actually see the MAF was defective or did you have a diagnostic run and they said it was the MAF?
I don't think it was the knock sensor that made my car better because I cleaned my MAF together with replacing the knock sensor. The knock sensor did increase my performance though. I have a rough idle now. Idk if cleaning MAF would do that. The car idled with out a slight rumble before this. But now I got a new code in check engine system which is 1302 or 1105 that read "map/baro sw solenoid/valve". Idk if that causes rough idle or not but its new. Clean MAF first. Can is 9$ at autozone. But I found MAF at Napa going for 187.00 for cheapest price
Old Jan 27, 2015 | 03:48 PM
  #47
CS_AR's Avatar
There are a lot of vacuum hoses in the area where you have been working. I would double check to verify there are no leaking vacuum hoses or hoses that may have been accidentally hooked up incorrectly.
Here's a video on the procedure to test the Map Baro switch. Take a look at the comments posted under the video. I think you will see your codes listed.
https://www.youtube.com/watch?v=a7eMmzW6zKI
Old Jan 27, 2015 | 06:34 PM
  #48
JLA117's Avatar
Yup, that's the exact video I saw earlier. Both the connector and switch is sparking up so they work. I might have to look at his other one that's related to the issue. Idk how I got that code. Maybe that's my rough idle issue. Autozone said to get a barometric pressure sensor. I'll keep investigating. Everything seems to be connected correctly too (all hoses)
Old Jan 27, 2015 | 06:48 PM
  #49
CS_AR's Avatar
Somehow I've managed to dodge the Map/Baro bullet with three 4th gens thus far. I've had many other problems except that one.
Maybe another member can jump in.
Old Jan 28, 2015 | 02:44 AM
  #50
JLA117's Avatar
Is that what's making the rough idle? My car idle like new before doing knock sensor and cleaning Maf
Old Jan 28, 2015 | 04:50 AM
  #51
theWalkinator's Avatar
Did you read my reply on your other thread about this?
Old Jan 28, 2015 | 10:51 PM
  #52
JLA117's Avatar
Let me re read because it blew up one day with comments
Old Jan 28, 2015 | 10:55 PM
  #53
JLA117's Avatar
For MAF, I went to cheap eBay one, I think it was around $50, 4 years already, works just fine, but last time I went to junk yard to pull a front wheel hub, I got a OE MAF too as spare, still in my garage.
Your MAF could be just dirty so before you commit to buy a MAF, try to clean it with CRC MAF cleaner, give it a really good spray, let it dry for 30 minutes before re-install, clear the code and drive for like 200 miles to see if the codes come back.
I did read and did clean MAF. There are no hose leaks and everything is connected properly. It is maybe Maf because the code popped up today for it. But still have the 1105 in there as well. Cleaning it didn't do anything. I did the knock sensor just to restore performance and want everything good in my car. It started studdering again today.
Old Jan 29, 2015 | 04:48 AM
  #54
Not this one, you have a separate thread about MAP code and I replied there.
Old Jan 29, 2015 | 04:55 AM
  #55
JLA117's Avatar
I replied back on the other thread
Old Feb 9, 2015 | 05:44 PM
  #56
TSoprano's Avatar
I had the same problem.. Car would shut off and shake and shudder but not always @ 3000 rpm. It started doing this very randomly. It actually would do it more when I'd be on a bumpy road or hit a pothole.. After some research I cleaned my maf, the car ran great for awhile afterwards. Then it started shuddering again. Never threw a code for anything.. Based on the fact that cleaning the maf did make it run better, I picked up an oem maf from the junkyard for $50. Installed it and the car has been fine ever since.
I remembered reading on here that the solder joints inside the maf can go bad. So just for te hell of it, I pried off the square cover on top of the maf and sure enough one of the solder joints was cracked. That little crack was just enough to screw it up when I hit a bump. I touched up the solder joint and re-sealed the square cap with some rvt so I should have a good spare if I need it later..
I'm not saying this is definitely your problem but it sure sounds familiar. When I posted about my problem alot of these guys on here really know their sht about these cars and they pointed me in the right direction. Hopefully you find out what the problem is too..
I think this is the thread I found out about the solder joints in.
https://maxima.org/forums/4th-genera...ml#post7963527
Old Feb 9, 2015 | 06:54 PM
  #57
luke95gxe's Avatar
haha my pic and maf
Old Feb 9, 2015 | 07:28 PM
  #58
TSoprano's Avatar
Originally Posted by luke95gxe
haha my pic and maf
Well then Thank You for that post and pic!! I'm sure it helped more then a few of us out..
Old Feb 9, 2015 | 11:23 PM
  #59
CS_AR's Avatar
Thank you both for the posts.
haha my pic and maf
I've got some failed MAFs in the workshop that hopefully I can refurbish using this information.
Hondarydr
Dec 30, 2024 06:15 PM
kingw323
20
Oct 21, 2015 08:36 AM
erniel
Aug 8, 2015 09:32 AM
maxima297
Aug 3, 2015 12:50 PM
