Specific Heater Core Bypass Question
Old Feb 9, 2015 | 08:28 AM
jmlee44's Avatar
Hey all, back again, 95 Max.
I have now experienced the air mix door failure (the one that controls the heat). It is stuck in "heat" of course, and as some may know, we use heat and A/c in the same day here in Texas during the Spring and Fall (sometimes even in the winter).
So, I really don't feel like tearing this apart right now.
Sure I can simply bypass the core, I know how to do that - but then I have no heat.
I want to install some aftermarket electronic heater control valve, under the hood, that blocks coolant flow to the heater core. My intent is to put a switch inside the car so I can turn this valve on/off remotely. I'm good with electrical, my question is - does coolant need to flow through the heater core all the time on this car?
I've heard some cars can have the heater core coolant flow blocked, but others it is part of the engine's internal bypass cooling and is necessary. Does anyone know for this generation of Max if it will cause any problems?
Old Feb 10, 2015 | 08:52 PM
arcticracer's Avatar
No problems with that and a cable actuated valve would be fairly easy to do.
Old Feb 11, 2015 | 09:04 AM
DennisMik's Avatar
I did a search on autozone.com for "heater control valve" and saw a few inexpensive ones that are operated by a cable. Most seem to be vacuum operated. I didn't see any electrical valves.
Check the hose sizes, because if you have to uses adapters, it can get pricey.
Here is the url: http://www.autozone.com/cooling-heat...h&newYmme=true
If the link doesn't work, you don't want to search using a specific car. When the select a car window pops up - close it.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 18, 2015 07:07 PM
pears
Sep 18, 2015 05:25 AM
jwright36
Sep 8, 2015 11:45 AM
