What fuse would cause my car not to start? (95 nissan maxima se)
Old Feb 16, 2015 | 09:52 AM
Grimlock's Avatar
Hi, I have a 95 Nissan Maxima SE and my car won't start I have a brand new battery, when I turn the key my lights and stuff come on... the car starter does NOT make a clicking noise when I turn the key... I took out my ignition switch check that... so I'm guessing is a blown fuse? but what fuse would cause my car not to start? I need the name, location and how much it would cost? and any additional help is welcome too.
Old Feb 16, 2015 | 10:08 AM
maxfever1987's Avatar
Just by looking at the ignition switch won't help you in any way, but there is a fuse in the engine compartment for you to check, it's located inside the drivers side fuse box, green color relay, I believe it says ignition switch or something like that check and report back, also to let you know 95-99 maximas do have a tsb on the ignition switches going bad,
Old Feb 16, 2015 | 10:21 AM
Grimlock's Avatar
Okay, Thanks so it could still be possibly the ignition switch? because I replaced it last year so maybe it burnt out again? and how would I know if that fuse is blown?
Old Feb 16, 2015 | 09:45 PM
DennisMik's Avatar
Is the car a manual transmission or automatic. The starting circuits are different.
The most likely causes of no start are: starter, ignition switch, clutch pedal interlock switch (manual trans), park/neutral safety switch. Fuses are wayyy down the list.
Old Feb 16, 2015 | 10:07 PM
^agree.
Hit your starter with a long pipe a few times and see if tries to crank over. If so, that's a tell tale sign your starter is toast.
Old Feb 17, 2015 | 12:28 PM
DBear's Avatar
Take a look here too: https://maxima.org/forums/4th-genera...ml#post8875419
Old Feb 18, 2015 | 11:02 AM
peb396's Avatar
Thanks to all
Came here today to post about this problem and saw this thread. Same problem that I am having. Will try the 'coke can remedy' linked above.
Old Feb 19, 2015 | 08:04 AM
Maxgig's Avatar
The fuse in the engine bay is actually a fusible link. If it blows you won't have any power at all, or when you turn the key. Since you do I would suspect the ignition switch or the lockout mechanism. (if your car is an automatic) Turn your key to the ACC position and move your gear selector thru all the gears, then put it in park and try starting it then.
Old Feb 22, 2015 | 09:47 AM
Grimlock's Avatar
Aight, Thanks guys... I order a new Ignition switch and Starter online since the parts are cheap... they should be here by Wednesday 02/25/15 I'll let Y'all know the status...
Old Mar 1, 2015 | 06:55 AM
Grimlock's Avatar
It was the Starter Defiantly and I switched out the ignition switch for good measure. Hope This helps some else out. and Thanks again guys for all your help!
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
kjm900r
Aug 5, 2015 07:14 AM
