electrical problems
electrical problems
ok so my car is a 95 maxima se m/t. I was driving home from work and all at once the battery and brake warning lights came on, the radio speakers (bose) quit working, the backlights in the cluster and clock went haywire going from bright to dim and back then flickering, and my headlights and fog lights turned off and now they wont turn on. ive searched the forum and from what ive found the warning lights are typical of the alternator going out. could that also cause everything else? the fuses are good, I swapped some relays and that didn't help either. im in the process of checking the headlight/turn signal switch now. anyone have any other ideas?
It must be alternator season already. I've had mine stop running when the alternator finally died.
Do you have a way to test your alternator for charging? If not, many auto parts stores (like Advance Auto) will provide a charging system health check free of charge.
Check out the following link and avoid products made or rebuilt in China.
https://maxima.org/forums/4th-genera...s-show-up.html
thanks CS__AR. i don't have any way of checking it other than a multi meter. ill just have to take it off and let the guys autozone check it out. by the way i forgot to mention that what ever happened caused the bulbs to blow. going by the fsm there are a few opens in the switch. so looks like im going to have to replace that too.
Replace the alternator and the light bulbs and see what happens before you replace the switch. Flickering lights are a strain for light bulbs and old bulbs will fail.
First thing after you put the alternator in is start the car and check the voltage. It should be about 14 volts, give or take a tenth of two. If it is out of range, get another alternator.
Testing with a multimeter is fine. Connect it to the battery. With the engine off you should read 12 volts. With the engine on the reading should go up to 14.2 volts. If it doesn't, or it's sporadic and unsteady, replace your ALT
1. Check your battery voltage first... car not running! 11.0-12v
2. Check your Altenator voltage second, 13.0v-14.2v ideal
3. Check your Altenator voltage under a load (headlights, foglights on, blower fan on high, emergency flashers, doors open, brakes on) 12.85v-13.8v
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
