Which front caliper slide pin?
Old Mar 14, 2015 | 01:23 PM
stromm's Avatar
Autozone website lists the "all metal" type like I've seen on every car I've owned.
http://www.autozone.com/catalog/comm.../H15009/image/
Autozone in-store system lists a different part number which one pin has a notch near the end that a plastic/rubber sleeve goes over. I've never seen this before, but that's what the parts guy says I should use.
http://www.autozone.com/catalog/comm...i/H5075/image/
Old Mar 14, 2015 | 02:01 PM
CMax03's Avatar
The first one looks like the Nissan Maxima brakes I'm used too seeing....
Old Mar 14, 2015 | 02:47 PM
DennisMik's Avatar
I think that photo is accurate. The one pin has a sleeve and the other pin doesn't. Never understood why.
Old Mar 15, 2015 | 04:10 AM
stromm's Avatar
So one for the "standard" slide pins and one for the sleeved pins...
my brain says putting that plastic sleeve in the chamber means it might break apart and cause a bind. Has anyone seen this?
Old Mar 15, 2015 | 03:56 PM
asand1's Avatar
Every caliper I've dealt with had one of each. The plastic bushed one trails. It is intended to reduce brake noise I believe.
Sent from my XT1060 using Maxima
Old Mar 15, 2015 | 04:56 PM
asand1's Avatar
Bosch Caliper manual PDF
Old Mar 17, 2015 | 02:49 AM
stromm's Avatar
Originally Posted by asand1
All well and good except stock calipers aren't bosch nor dual piston...
Old Mar 17, 2015 | 05:26 AM
asand1's Avatar
Irrelevant. Whether Bosch or not, the plastic (rubber really) bushing is a better design and the norm, and would be the better choice. If you like loud brakes then by all means go metal on metal.
Old Mar 17, 2015 | 08:34 AM
RA030726's Avatar
I'm nutty for Nissans
Yes they can fail. I had to replace the pin guides (or bushing) on my Frontier. They got hung up in the torque member and caused the brakes to drag.
Old Mar 17, 2015 | 02:06 PM
stromm's Avatar
Not arguing, but it is relevant. Different caliper/braket designs may have different guide pins.
Just looking at the FSM, there is no sleeve. Looking at AdvanceAuto, not sleeve. Looking at Autozone's website, no sleeve. Only the in-store computer lists the sleeve.
I posted because of the twenty or so cars, domestic and foreign, I've done disc brake jobs on, I've never seen pins with sleeves. I'm OK if it's a redesign and applicable for STOCK calipers and brackets.
My concern is that Autozone is pushing this design because it appears to be what their caliper kit uses. And that the sleeve will break apart causing problems with travel of the pin.
Old Mar 17, 2015 | 02:10 PM
CMax03's Avatar
Pull yours apart to see what you need dude!!!!!
Old Mar 17, 2015 | 02:18 PM
CS_AR's Avatar
Over the years I've been using this type of red rubber grease on caliper pins and seem to avoid problems.
Old Mar 17, 2015 | 04:50 PM
asand1's Avatar
For the twenty years I've been working on cars, including dealer and Indy employment I have seen enough bushed pins that I would not worry about it. If a bushed pin was available I would use it, they don't fall apart.
Maxima's don't come with coilovers and and HID projectors, is that reason enough not to install them?
adamgalazka
Feb 5, 2023 08:24 AM
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
