'Spose I'll Need To Recalibrate My TPS?
Old Mar 23, 2015 | 07:27 AM
Turbobink's Avatar
Let me qualify by saying that I have zero reason to believe there's any malfunction.
However, I've been quite involved in an injector fix and while the car has been apart I've been taking care of a good number of other things that one just takes care of while his car is apart.
For some damn reason I thought it would be a good idea to remove my TPS before I realized I really had no reason to remove it.
Simply based on the removal and immediate re-installation of the sensor, do you guys suppose I'm gonna need to recalibarate it?
Old Mar 24, 2015 | 02:49 AM
CS_AR's Avatar
Here's a link on how to check/adjust the TPS below.
http://vbxmaxima.8m.com/tps.html
Old Mar 24, 2015 | 07:21 AM
jholley's Avatar
No doubt you'll need to accurately mount that TPS. Measuring the resistance of pins 2 & 3 on the potentiometer before removing it is one procedure to get it mounted back to within it's same range. Another way to readjust it using a feeler gauge on the CTPS (Closed TPS) switch. This bulletin defines that procedure
http://lyberty.com/car/Maxima_A32_do...NTB99-053b.pdf
You'll also want to replace those phillips headed bolts with hex headed ones. Using the tip you gave me a few weeks back I removed those phillips headed brass bolts on the FPR and inserted allon headed bolts. Not enough clearance room to mount hex headed bolts in there.
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
sake1bs
Sep 19, 2015 09:32 PM
nizmolee
Aug 22, 2001 12:34 PM
