bar under my engine is cracked
Old Apr 6, 2015 | 09:54 AM
Dubisis91's Avatar
whats up folks I have a 5 spd and i noticed that a bar or rod of some sort is cracked and its making my engine sit low and un even im sure and im wondering if this is a common problem and what to do about this. is there a welding option or do i have to replace the whole support system
97 maxima
Old Apr 6, 2015 | 12:13 PM
JLA117's Avatar
It's the bridge that connects with the motor mounts isn't it? You will most likely have to replace that if it is. If not the motor mounts will hang with the engine.
Old Apr 6, 2015 | 01:50 PM
JDezMax95's Avatar
I believe it's your crossmember. I would go to a junkyard and swap it.
Old Apr 6, 2015 | 02:52 PM
asand1's Avatar
How about a photo. Might be the core support.
Sent from my XT1060 using Maxima
Old Apr 7, 2015 | 04:21 AM
dwapenyi's Avatar
How do you even crack a crossmember? This vehicle must have some kind of dubious history.
Old Apr 7, 2015 | 08:07 AM
Dubisis91's Avatar
I'll take photos and post them once I get off from work
Old Apr 10, 2015 | 04:23 PM
Frank Fontaine's Avatar
Man he's been working a long time
Old Apr 10, 2015 | 05:34 PM
Fakie J Farkerton's Avatar
Probably couldn't figure out how to post the photo.
Use photobucket OP!
Old Apr 27, 2015 | 07:15 AM
Dubisis91's Avatar
OK sorry I went Mia phone was broken. But I found out its my radiator support rotting away smh guy told me to sell the car it's not worth it and guy at maaco said 700 and he will help me out
Old Apr 30, 2015 | 12:34 AM
luke95gxe's Avatar
Ill help u out oem is like 120 for lower and ill weld it in for 100 looks like 220 gets it done an i hope you never speak with a guy from macco afain an btw fire your mechanic he sux
Old Apr 30, 2015 | 06:17 PM
Wolcottmax1's Avatar
Changing out the cross member is not that difficult to do. As far as it rotting out, it is pretty common depending on where you live.
Starrider
Dec 18, 2015 04:43 AM
