Any ideas for this little problem?
Old Jan 25, 2002 | 12:03 PM
kash2776's Avatar
Hey everyone. I'm a new member here. Can't believe I never joined earlier considering how much of a Max fan I am. Owner since 98.
Anyway, my car has been doing something kinda weird. When I'm coming to a stop at a light or whatever, I shift into neutral and the rpms drop down low and then come back up to idle. They do't go extremely low but enough for me to notice. It doesn't seem to happen when the A/C is on however. I recently did my tune-up and cleaned out the throttle body and new fuel filter, etc so it shouldn't be a fuel problem. I also checked the mass air meter and saw it was clean. Could this have something to with the idle air bypass valve?
Any comments/suggestions would be appreciated. Thanks.
Old Jan 25, 2002 | 12:31 PM
ejj's Avatar
ejj
Re: Any ideas for this little problem?
Both of the Max's I've owned do that. I just wrote it off as being kinda normal. When the AC is on the ECU has the engine idling higher to run to compressor...so you wouldn't notice it then as you noted.
Old Jan 25, 2002 | 12:33 PM
jiaxima96's Avatar
My 96 GXE auto does the same. At idle when I shift from D to N, the idle drops a little then comes back a little. It's been doing that for a long time. I'm not sure if it's a problem, but guess not. There is always a transition time that whatever the controlling unit need to take, when engine load changes.
Old Jan 25, 2002 | 01:00 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
when you shift back to drive does it act the same?
Old Jan 25, 2002 | 01:11 PM
kash2776's Avatar
Re: Re: Any ideas for this little problem?
Actually, my car is a 5spd. And it only happens when I'm rolling and put in neutral to come to a stop. The whole incident happens for about a second. I only recently started noticing it...
Old Jan 25, 2002 | 01:17 PM
deezo's Avatar
I've noticed that to be the case with most fuel injected autos I've driven in the last 6 years. I would say its the ECU doing some calculations to get the idle back on track (I could be wrong).
Old Jan 25, 2002 | 01:31 PM
VeeQueue's Avatar
Re: Re: Re: Any ideas for this little problem?
maybe there are deposits the IAC valve . try taking off the air cleaner assembly and spray some air-intake cleaner (i use crc brand) in the throttle body and see if it'll help. it might be a cheap simple fix.
matts95max
Apr 23, 2025 10:44 AM
Mar 12, 2020 12:06 AM
thenewguyy
Sep 12, 2015 11:12 AM
slowlifer
Sep 8, 2015 05:53 AM
