Remote Line...
yeah, but make sure you dont hook it to the CONSTANT 12V power wire going to the cd player, this would cause it to be always on. i think there should be a remote turn on wire - in most cases it will be a blue and white wire
correct me if im wrong
Adding Subs and amp...
I have the remote going to the wrong blue wire, Its stays on constantly. I'm goin tap it to the other blue wire and see what I get. The Amp is in the trunk, so I had to run a wire up to the dash. the power and groud are all ok, and connected good. Fused off, distribution block, etc, just didn't want to hit the wrong wire for the remote, which happened anyway!
Thanks,
Phantom
Thanks,
Phantom
Originally posted by 95emeraldgxe
what are u doing exactly? - new system?? or u just making a few minor mods?
Maybe this will be of some assistance:
http://www.installdr.com/InstallDoctor/QuickWiring.html
Are you using an aftermarket HU? Or the stock one? And you can leave the tap hooked up where you have it now if you want. You just need to intall an on off switch in lione somewhere and then remember to flip it off when you're not using it. It's pretty simple to do. E-amil me if you decide to do it and need help.
lowpost99
Oct 26, 2025 06:53 PM
ToTheMax305
Sep 23, 2015 09:11 PM
