car will not start
Old May 3, 2015 | 12:16 PM
aobomb99's Avatar
car will not start
Hi I have been having trouble starting my 1997 nissan maxima . If I put key in it will make one click and that's it. The radio and everything else works. We have had advanced auto zone test starter and it was fine. Changed out ignition switch and inhibitor relay. Still does the same thing. Anyone have any ideas.
Old May 3, 2015 | 12:43 PM
JoshG's Avatar
battery? is your terminals charging it properly?
Old May 3, 2015 | 01:24 PM
DennisMik's Avatar
Time to get your voltmeter out and do some troubleshooting.
Here is a link to a troubleshooting thread for the 5th gen Maximas, but it applies to the 4th gen as well:
https://maxima.org/forums/5th-genera...rt-thread.html
Old May 3, 2015 | 02:00 PM
chrome91's Avatar
check battery and starter cable connections. also the chance that its an intermittent solenoid or gear tooth failure on the starter
next time it only clicks, try starting it in neutral as well (foot on the brake obviously)
Old May 3, 2015 | 04:03 PM
aobomb99's Avatar
Won't start
1997 nissan maxima won't start. I turn the key and it makes these 3 clicking noises and that's it. Just put new starter on and it is getting power. Also have a new ignition switch. Took battery in to advanced auto zone and thy tested it says it was good also was charged a little. Could there still be a bad battery? Don't have a way to test amps. Also tried starting in nuetruel Not sure what else to do
Old May 3, 2015 | 04:23 PM
martyl45's Avatar
CEL?
Bad ground?
Could always buy a new battery and return it afterward
Old May 4, 2015 | 12:24 PM
DBear's Avatar
This might be a possibility: https://maxima.org/forums/4th-genera...ml#post8875419
Old May 5, 2015 | 06:49 AM
ChemDog's Avatar
Start
Noob here but had the same problem a while back. Also thought was ignition switch but turned out to be my alternator
Old May 5, 2015 | 08:56 AM
M in KC's Avatar
Is the Bendix engaging on your new starter. There have been reports over the years of bad starters right out of the box. And again for everyone's benefit, your symptoms are no start vs. no crank. Correct.?
Old May 5, 2015 | 11:48 AM
zizi195's Avatar
my 97 has the same problem
sanded the grounding cables new battery new starter our 6th starter between 2014 and 2015 right now its sitting in the back yard sleeping its *** off full tank of gas 280,233 miles
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
