5 spd tranny starting to go
Old Jun 13, 2015 | 09:10 AM
Daniel VQ30life's Avatar
my 97 5spd is looking like she'll be getting a new tranny soon. I've been wanting to do an lsd swap, but wanted opinions
lsd or 6 spd?
looking for opinions from those who have done either or both in a fourth gen. pros, cons, cost factor. just looking for advice to base my decision
Old Jun 13, 2015 | 09:42 AM
Fakie J Farkerton's Avatar
lsd or 6 spd?
HLSD 6 speed. Timing rings are available now from Schmellyfart.
Old Jun 13, 2015 | 10:11 AM
dwapenyi's Avatar
An HLSD 6 speed would be the ultimate, but even a regular 6-speed open diff would be better than a 5 speed with VLSD. The closer gear ratios, and more of them, offering faster acceleration AND better fuel economy, would trounce the added cornering grip that going from an open diff to an LSD provides. Of course any 6-speed swap will be more work involved than a 5 speed.
My previous Maxima was a 98 5-speed and my second is a 98 I30 5-speed. So I went from open diff to vlsd. Differences? Yeah, but not night and day. The VLSD would benefit someone who drives aggressively alot, or drivers in Canada with long winters and slippery road surfaces.
Old Jun 13, 2015 | 02:17 PM
how difficult is it to find the hlsd 6spd in jy's? and could the swap be done "realistically" in a weekend by someone who is not a mechanic but mechanically inclined.
i do most of my own work if i have time and tools, but ill be honest, I'm an electrician, not a master mechanic
Old Jun 14, 2015 | 12:23 AM
dwapenyi's Avatar
I will let others with more experience chime in as I've never done the swap myself.
Also keep in mind that part of the reason the 6 speed swap is more work is because you are modifying the rod shifter mechanism of the 5 speed to a cable shifter mechanism of the 6 speed.
Nissan made some effort to suppress the NVH of the bigger VQ35 engine.....cable shifter.....dual mass flywheel.....etc
The VQ30 is killer smooth NVH so you can happily stick with single mass flywheel, and perhaps even "downgrade" the cable shifter to a rod shifter in your 6 speed install, although I don't think that has ever been done.
Old Jun 14, 2015 | 02:19 PM
i think at the moment I'm still leaning towards 5spd lsd. i want the swap to go smooth, and i don't necessarily want to be shifting more than i already am, Atlanta traffic can be a real headache
of course tho I'm still open to all advice and suggestions
Old Jun 14, 2015 | 04:35 PM
JEB Davis's Avatar
I would vote for the 5spd LSD... I get a big thrill out of smoking BOTH tires, laying 2 rubber stripes.
And the car goes through snow like no other FWD car I've owned, it's awesome in the winter.
Old Jun 14, 2015 | 05:25 PM
I'm not worried about smoking my Goodyear eagle gt's
nor does it ever snow in Atlanta
Old Jun 14, 2015 | 09:25 PM
Finkle's Avatar
I was drooling over a 02 6sp sitting in the junkyard when I was doing my 5sp swap due to a worn out input shaft bearing. There was just too much work to justify the extra gear. From what I remember, the trany mount has to be welded or bolted on, the cables have to be run through, and then there is the timing gear issue. Between all three it just wasn't worth it. I think about that 6th gear every time I'm going 75mph and pushing 3 grand.
Old Jun 14, 2015 | 10:30 PM
https://maxima.org/forums/all-motor/...-6mt-swap.html
Old Jun 15, 2015 | 02:06 AM
that's pretty much how i feel about it
Old Jun 15, 2015 | 08:57 AM
aackshun's Avatar
6mt awl day, every day.
Even an open diff 3.8 geared (02-03) 6mt is leaps and bounds better than a 5mt.
Old Jun 17, 2015 | 08:30 AM
cashoit's Avatar
yo Acck Mang....am I reading your sig correct?? Did you convert an I35 to a 6spd MT???
Thats sick man.
OP,
Obviously there are pros and cons of each swap:
Stock would be the easiest replacement. 6 spd MT route most difficult replacement.
In terms of price, the stock replacement will be most cost effective option.
In terms of fun....sorry acck mang, I gotta go with stock. I like the gear spacing better with the 5spd.
Fuel economy definitely goes to the 6spd however. U can get maybe 30mpg highway.
It really comes down to how much work you wanna do. I assume you will be doing the work as no garage would ever guarantee this work and the labor costs would be astronomical.
Old Jun 17, 2015 | 11:45 AM
aackshun's Avatar
-Jes.
Thats sick man.
-Jes it is.
OP,
-Depends on the time span, over a year a 6mt will be cheaper, if you just want the car running quickly and cheaply and don't have any long term commitments to it then 5mt is the way to go.
-Please tell me you're speaking from experience.
They still let you use this thing?
I want to edit my original statement.
A transgo VB mod 4AT is even better than a 5MT
6mt > me > you > the dirt > 5mt
Old Jun 21, 2015 | 09:55 AM
ok, question, can a open diff 5 speed be rebuilt into an lsd? a local member has a good 5 speed open diff for a couple hundred, i would like to just straight swap and rebuild my current one
Old Jun 21, 2015 | 09:56 AM
oh and deCided 6 speed is out of the question, i daily this thing and i can't afford to have it down for long just for another gear, besides I've always had 5 speeds, it's what i know and love
i do appreciate everyone's input
Old Jun 22, 2015 | 01:37 AM
dwapenyi's Avatar
...... besides I've always had 5 speeds, it's what i know and love.....
Really? You make it sound like you are about to learn a whole new type of transmission. Its just one more gear
Anyhow, I do understand that because the 6 speed swap is more of a challenge I would also lean to the 5-speed as well. Still, in my dream garage I would have 4th gen 6-speed HLSD with a conversion from cable shifter to straight rod. Now THAT would be just too awesome
Old Jun 22, 2015 | 04:59 AM
future goals, by the end of this year i plan to have as brand new car for the wife and I'll start to daily her Camry, from there, the max can be down for extended periods and more extensive projects will be done
Old Jun 22, 2015 | 06:30 AM
aackshun's Avatar
You're dead set on the matter.
What do I know, I'm only speaking from experience.
Old Jun 22, 2015 | 07:05 AM
what? are you like butthurt because I'm not doing a 6 speed swap? please share
Old Jun 22, 2015 | 04:00 PM
315max's Avatar
i have an lsd 5spd that im selling...
Old Jun 23, 2015 | 03:10 PM
price? location? condition?
Old Jun 23, 2015 | 04:01 PM
Nealoc187's Avatar
SLOW
the case is different on the VLSD from the open diff, so you would need at least the top half of the case, the diff, driver's side diff bearing and ring gear and bolts. it could probably be done if someone were dead set on it but it's way easier to just buy a VLSD. would also be easier to just accomplish a 6spd swap than to make an open diff trans into a VLSD unless you're at least moderately experienced at building transmissions.
Old Jun 24, 2015 | 01:47 AM
that's the kind of advice i love to get. I've never rebuilt a tranny before and had wanted one for a project to learn on, i may still rebuild this one but after hearing this i think for first time I'll stick with straight rebuild and depending on how that goes maybe try the lsd rebuild in the future, depends also on my wife's patience with me and the car
Old Jun 24, 2015 | 06:57 PM
315max's Avatar
its located in ny, shifts fine, needs a new axle seal. will come with the drivers side axle as it is different between open and lsd. price is 400obo+shipping
Old Jun 25, 2015 | 03:53 PM
thanks but too far for me to consider
pktaske
May 6, 2016 07:49 AM
220k+ A32
Sep 11, 2015 02:18 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
