huh? how do i remove my stock shifter?
Old Jan 26, 2002 | 03:18 PM
Mad Dhan's Avatar
i cant seem to even turn it a little bit, is it a screw? if it is not a screw how did u guys remove it?
Old Jan 26, 2002 | 03:24 PM
NickStam's Avatar
Re: huh? how do i remove my stock shifter?
it's threaded on, but glue is also used. i suggest that you wrap a towel around the shifter and then used a wrench to twist it off. you should hear a crack when the glue breaks.
Old Jan 26, 2002 | 03:36 PM
Mad Dhan's Avatar
Re: Re: huh? how do i remove my stock shifter?
would i be able to re-attach the shifter later if i do this or will it be all loseand not sit properly, thanks nick
Old Jan 26, 2002 | 04:17 PM
Mishmosh's Avatar
Re: Re: Re: huh? how do i remove my stock shifter?
If the plastic insert gets cracked in the process, it will be loose. Otherwise it will be snug but you still need glue to fix it in place with the proper orientation; after it has been loosened, if you try to re-tighten it down, the **** will stop with the **** at an angle...
Old Jan 26, 2002 | 04:27 PM
98BlaximaSE's Avatar
I took some bubble wrap i had laying around, wrapped it around the shifter, and then used a monkey wrench to twist it off. after I loosened it I took it off by hand.
Old Jan 26, 2002 | 06:21 PM
Mad Dhan's Avatar
Thanks for all the responses guys, really helped
Old Jan 26, 2002 | 06:58 PM
sil SE's Avatar
you guys are all right but F THAT - mine was jus SO DAMN hard to get off i had to cut the **** off- its jus stupid rubber anyway
****ed me off
Old Jan 26, 2002 | 07:35 PM
nigelcmf's Avatar
Bubble wrap? I am suprised that worked! There are quite a few write ups on this subject search around. I think they reccommend using a towel (to wrap the ****) and vice grips to turn. You will hear a pop or crack when the **** moves.
Old Jan 26, 2002 | 07:50 PM
Well I had some laying around from something i ordered. The towel keep slipping and I could really get a good grip from it. The bubble wrap gripped pretty well though. Got it loose in one twist.
Old Jan 26, 2002 | 08:15 PM
nigelcmf's Avatar
Well a wet towel DOES work!
Old Jan 26, 2002 | 08:18 PM
nigelcmf's Avatar
Sorry ... don't mean to argue....that probably sounded harsh! I had the same problem with dry towel, just wet it and it gives a lot more grip!
Old Jan 26, 2002 | 08:19 PM
95emeraldgxe's Avatar
u cut it off! - whoa - that was purdy drastic.......but u got a ghetto short throw shifter now - haha
Old Jan 26, 2002 | 08:43 PM
sil SE's Avatar
yup drastic but the thing was aggravating.
i dont consider it a ghetto short shifter- i call it a cut down stock shifter
i stated before that a STS and cutting down are two COMPLETELY diff things- as long as you know the throw will still be the same travel and dont call it a sts if its not
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
bumpypickle
Sep 20, 2015 08:22 AM
Violator
Sep 9, 2015 10:14 AM
