95 max no start please help
Old Jul 10, 2015 | 07:05 AM
gldmaxx98's Avatar
so here we go so far replaced starter; cam sensor;crank sensors fuel pump and no start cranks over but wont fire getting power to injectors and coils but not getting any voltage at cam or crank sensors the car was fine but out of no were was driving and just died any help please thanks in advance:confused: 1995 Nissan maxima
Old Jul 10, 2015 | 07:13 AM
NissanNismoZ's Avatar
Do you have a way to check the codes? Maybe you can check the codes and see what the car is trying to tell you. Weird question..but the timing chain didn't break did it?
Old Jul 10, 2015 | 07:17 AM
gldmaxx98's Avatar
since its a 95 I cant check codes I don't know how to read codes on this year I don't think the chain broke cause I took off the oil cap and my cam spins I understand its not getting power to cam or crank sensors
Old Jul 10, 2015 | 07:20 AM
rhonster's Avatar
Originally Posted by gldmaxx98
so here we go so far replaced starter; cam sensor;crank sensors fuel pump and no start cranks over but wont fire getting power to injectors and coils but not getting any voltage at cam or crank sensors the car was fine but out of no were was driving and just died any help please thanks in advance 1995 Nissan maxima
check your alternator ? (as to previous, the engine would not turn over if a timing chain(s) was broke and you can access your cpu codes with a screw driver just beside the gas pedal but it doesnt sound like its throwing a code)
Old Jul 10, 2015 | 07:26 AM
gldmaxx98's Avatar
check for power I jump started and still noting I also have a full charge on my battery also were do I read the codes from im new to the 95 I also have a 01 and a 98 5speed never had a problem like this its not the alarm I check all that out please and thank you
Old Jul 10, 2015 | 07:58 AM
jerrod99_se-l's Avatar
Have you checked to make sure you are getting fuel pressure and power to the coils? If all that is in check....I'd look at the ecu...
Old Jul 10, 2015 | 08:48 AM
DennisMik's Avatar
If you don't have the service manual, here is a link to it:
http://boredmder.com/FSMs/Nissan/Maxima/1995/
The FWD.PDF file is the cover page that will tell you what all the sections are.
The IDX.pdf file is the alphabetical index for the manual.
Here is a video on how the check the codes on a 95-99 4th gen Maxima:
02PearlSE
Oct 7, 2015 02:12 AM
neilraz
Sep 11, 2015 07:36 PM
MaxLife17
Sep 8, 2015 02:36 PM
Hailstatejig
Sep 2, 2015 06:52 AM
Balkins
Aug 12, 2015 06:39 AM
